Paint Coming Off When Washed - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 11:44 PM   #16
Faron79's Avatar
Rewards Points: 260
From a "Technical" standpoint, a Semi-gloss is best...because higher-sheens have a smoother/tighter resin film.
Thus, they clean much easier!!
The "appeal" of shinier films is pretty subjective!
Some of our customers LOVE Flats...some HATE the look of a Flat.
Up here, ACE's Royal & Royal-Finest (ACE's top paint series) are very good paints in the Mid-$20's/gal.
The Scotchguard-treated Royal-Finest (~$32/gal.) cleans SUPERBLY. If you went this route, you could use an Eggshell sheen.
If you wanted the "conventional" paint, use a Satin.
These are very popular paints here.
No matter what ya choose...apply 2 full coats, and let cure 3-4 WEEKS b4 washing.
Faron
Faron79 is offline   Reply With Quote
Old 04-14-2011, 06:36 AM   #17
Gymschu's Avatar
Rewards Points: 658
...............still wondering why someone would clean walls after they had been painted just 2 days previous.
Old 04-14-2011, 06:51 AM   #18
ok
She had some kids over and they got pop on the walls she said..
canadacatman is offline   Reply With Quote
Old 04-14-2011, 09:52 AM   #19
Faron79's Avatar
Rewards Points: 260
Sounds like quite a party!
If stuff gets on the walls after your "newest" paint-job, wipe-off LIGHTLY for 3-4 weeks.
Curing-out/hardening CAN take 3-4 weeks, as I mentioned.
Depends some on each homes' humidity, airflow, etc.
Faron
Old 04-14-2011, 11:27 AM   #20
ok
Ya maybe she pressed too hard but i was there and when you walk down the hallway you can see where she cleaned it before you get to the actual spot..
Old 04-14-2011, 03:01 PM   #21
Originally Posted by DrHicks View Post
The main reason I tend to go with Behr Paint is because there's a Home Depot nearby, and the smaller paint stores are much farther away. Also, I apparently live near the only HD that has a decent paint department, and people who can mix the paint properly. I'm by no means married to Behr Paint, but I've never had any problems with it.
I've used Valspar quite often, and like it. I've used Glidden. Its higher-end lines are fine.
Sherwin Williams Paint is very very good. But my experience with our local store was that they are arrogant butt-holes. And frankly, a 5% discount on $55 per gallon paint isn't good enough. Hopefully your experience will be better.
You should also check out Scott Paint....they are florida's best paint and now have an online website and ship right to your door via UPS. They specialize in mildew resistant coatings. I used the all grip paint when I repaint....it sticks to old alkyd (oil based) paints without any priming or sanding... and covers great. They have a satin, a semigloss, and gloss.
check it out at
www.fortune3.com/scottpaint
shemp is offline   Reply With Quote
The Following User Says Thank You to shemp For This Useful Post:
DrHicks (04-14-2011)
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
new windows coming...need to paint Dusty Painting 1 11-01-2006 01:38 PM
