#1 |
Paint coming off the walls
Hi,
My name is Jim and I have a problem with paint coming off my walls when something is leaning against them for a period of time. The problem is, that when I go to relocate the item (gun in a gun case for this example) it is stuck to the wall? I can see this being a problem if the wall was freshly painted, but the paint is 6 yrs old? We tore the drywall where it was leaning against. The other day, we went to remove an ironing board that was leaning against the wall and the same thing happened - different room, different color of paint. It actually is tearing into the dryway when we try to remove. Has anyone else seen this or have a solution to our problem? Any help would be much appreciated. Jim |
#2 |
Rubbin walls since'79
What is happening is the latex paint is forever sticky. This will usually happen with cheaper paints that use lower quality resins.
Do you know exactly what the paint was?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
#3 |
Latex products, especially cheap ones as BJ mentions, are more prone than good acrylics.
Of course there could be an adhesion problem because of poor surface prep or a primer was needed and not applied.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
BJ & Sdsester are right on it as always. My guess is poor prep, meaning that there was probably a semi-gloss paint on the wall and someone painted over it without scuff sanding to remove some of that gloss. The new paint never properly adhered, especially if it was a cheap paint full of chalky filler material.
#5 |
paper hanger and painter
to all three of you
after 6 years?
#6 |
I've seen some old style latex stay rubbery for ever- particularly if it was "semi gloss"
#7 |
Chris. Good point. But I have encountered six year old paint, usually vinyl latex compounds, that can be peeled off in sheets.
#8 |
Chris, it may be that they are just discovering this problem after leaning heavy items against the wall. I have seen apartment repaints where there was a loose area in a lower corner, someone picked and pulled on it and the whole wall came off in sheets. Not common but the apt hadn't been painted in 7 or 8 years.
#9 |
I guess it could happen as you all have pointed out, just never seen what the op posted after that length of time.
#10 |
Thanks for all the responses, which all makes sense but here are some more details that might narrow this down.
#11 |
If they sprayed on primer without back rolling to work it in and the walls were still dusty from the sanding- that would be one reason for bad adhesion.
And behr , particularly its lower lines, has been known to have this problem.
#12 |
.........yet another reason to avoid BEHR paint at all costs, not to mention the crappy primer most builders apply to the walls, usually the cheapest they can find.
#13 |
Thanks again all for the great information and now my next set of questions
#14 |
Jim primer and paint do not come in the same can. It is pure marketing hype.
For your situation, you should remove as much peeling, chipping, otherwise failing paint as you can. Prime with a high bond waterbased primer. Then using a nice wide drywall blade and drywall compound, skim coat the walls as needed to blend in the areas where you peeled off paint. Prime the drywall patching. Apply two nice coats of real paint store finish. Buy as close to 100 percent acrylic as your budget will allow.
#15 |
Guys maybe I'm reading this wrong or maybe reading too much into it, but if this paint has been on for 6 years and stuff is just starting to stick to it, and surely in 6 years something has leaned against it. Then it almost sounds like the paint is just starting to soften. I don't have a clue what would cause this, but if this is true I don't think you can just paint over it could you.
Maybe Ric knows paint would have an answer or a theory. |
| The Following User Says Thank You to ToolSeeker For This Useful Post: | Gymschu (11-30-2012) |
| Display Modes | |
| Repainting Room With Peeling Paint: Advice Needed | Magnetic | Painting | 8 | 10-15-2012 06:19 PM |
| Painting Old House | Smokin Gun | Painting | 36 | 07-05-2011 02:24 AM |
| Basement Walls - Which Paint?Drylok? | HandyFrank | Building & Construction | 3 | 10-17-2010 01:07 PM |
| latex paint over oil-based = peeling paint! help! | ImaDIYnewbie | Painting | 5 | 09-20-2010 05:48 PM |
| Painting patch in bathroom | ohman | Painting | 4 | 09-15-2010 11:09 PM |
