-   -   Paint coming off of siding (http://www.diychatroom.com/f4/paint-coming-off-siding-9420/)
ciera 06-25-2007 10:59 AM
Our house is dirty, so our neighbors suggested that we use their power washer to clean it. Bad idea.
It removed the paint from the siding, so I inadvertently graffitied our house. We took a rag and wiped across the siding to smooth the paint, and it seemed to do the trick. I then tried just a hose, and that also removed paint. It looks like ANY water on our siding causes the paint to run. As soon as it's wet, we can touch it with our fingers and they come away white. You can actually see areas where the siding is higher up and the brick is below it, and the paint has run onto the brick.
Most of the siding is aluminum, but there's one part that's vinyl. Both cause the paint to run, but it's not as obvious on the vinyl.
Sooo...
1) Does this mean that the siding is bad, or the paint is bad?
2) If the paint is bad, can we paint the existing siding, or do we have to redo that too?
3) How do I remove the paint runs off the brick?
4) How do I clean the siding? It's really dirty...
slickshift 06-26-2007 06:39 AM
Usually it just means it's old
Maybe it wasn't the best siding when installed, but that doesn't mean it's "bad"
...unless the siding is relatively new
That would be bad siding
You can paint it
It won't be as easy as throwing a coat of paint up there, though
To get something to stick would require extra effort
Re-siding could be a viable option
Best to wet the brick before washing the siding, then douse them good and often while washing
There is only so much you can do...
But don't let the run-off dry
You can get commercial products at you local paint store or home center
But if it's that dirty, and the paint is running off like it seems, depending on conditions and age, and what's left after cleaning, it may be time to consider re-siding
joewho 06-27-2007 12:10 AM
What paint is coming off? I mean, was the siding actually painted with latex paint? Or is it the siding paint coming off? If it's the siding paint coming off, it may just be the oxidation, or chaulk you see running down.
The power washer should take it off the brick.
ciera 06-27-2007 10:01 PM
I think it's the siding paint. I doubt these guys would ever have painted the house. That would be like, doing maintenance or something! Shock!
So, you think residing is a better option than painting it? What kind of work would to require to paint it and make it stick?
boman47k 07-01-2007 04:58 PM
Had the same thing to happen a couple of years ago. Could wet finger and wipe oxidized paint off. Washed what I could, oil primed bare spots and painted. Read an article since then that suggwsts good washing, thinned down oil primer ( pint thinner per a gal.) and 100 per cent acrylic paint. If this is aluminum.
redline 07-01-2007 05:22 PM
scrap off the loose paint, prime and then finish with a top coat of paint.
