Paint Coming Off Like Plastic - Painting - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 09:10 AM   #1
Paint coming off like plastic
Some background information on my new old house. The house was built in 1994 and the previous owner went in there 2-3 years ago so I'm guessing the paint is that old. Started taking off the switch and outlet face plates when the old paint started stripping. I was able to pull large chunks of paint off the wall like plastic. This happened in at least 4 walls and I see it happening in the whole living/dining/kitchen area. Not sure about the rooms.Am I going to have to strip the whole thing down? I'm afraid to start painting over it as I'm sure that paint will come off as well.
Attached is a pic of one section where paint comes off. Note that if I keep pulling it'll keep coming off.
Please help!
Link to video:
http://s133.photobucket.com/albums/q...00603-1926.flv
scorp58 is offline   Reply With Quote
Old 06-04-2010, 12:37 PM   #2
For it to come off like plastic makes sense, latex is plastic. It looks like the underlying surface is some kind of stucco (which I have never worked with), and where the underside of the paint is white ... my guess would be that the surface of the stucco is seperating. Maybe someone else can speak on whether or not the surface needs to be sealed first?
gdoucette is offline   Reply With Quote
Old 06-04-2010, 03:20 PM   #3
the underlying surface is drywall that has been textured, I've been told that it's called Monterey Drag knockdown pattern
Old 06-05-2010, 08:55 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Either the texture was to blame (not taking the paint) or the first coat over the texture was cheap paint. You will need to get as much of it off as you can and then use a slow drying penetrating oil based primer to lock down that surface and make it able to take paint.
Old 06-07-2010, 09:36 AM   #5
fellow at Benjamin Moore said that it was probably caused due to painting over a chalky surface. Before I was aware of this issue I had bought a 5 gal. pail of Promar 400 tinted for my topcoat, will this primer do if I remove all of the paint and dust it all off?
Old 06-07-2010, 05:15 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
yes
Old 06-07-2010, 05:34 PM   #7
Rewards Points: 530
Maybe if you had thought to cut the paint around the covers....? Or did you?
Is that primer on the back of the paint peel?
Old 06-09-2010, 09:32 AM   #8
I did cut around the corners on the rest of 'em but I already started removing the paint from the walls. It's been real easy as I don't even have to scrape at all, the paint comes off just by pulling it. Two bedrooms are in the clear, they're both painted in flat paint and did adhere to the walls, but the rest of the house is in semi-gloss and peels off real easily.
Pic of the family room stripped off paint
Another wall
Old 06-10-2010, 05:31 AM   #9
Paint Store Dude
Hi,
The Pro 400 is not primer. It is a finish paint. If you are dealing with SW get some Multi Purpose latex primer or another primer recommended by SW. This will assure correct adhesion to the walls. It is OK if you have it tinted. Then put 2 coats of the 400 over it. Just make sure the walls are clean. Rub the palm of your hand over the wall and if your hand has dust on it then there is more cleaning to do. A lightly damp rag or sponge would be OK, just make sure to let it dry very good before putting the primer on.
Chazbe is offline   Reply With Quote
Old 06-10-2010, 05:15 PM   #10
chrisn's Avatar
Rewards Points: 496
Originally Posted by Chazbe View Post
Hi,
Wow, my mistake, I am not all that familiar with SW products and just assumed that scorp58 knew it was a primer, sorry.
Old 06-10-2010, 06:35 PM   #11
Paint Store Dude
Chris,
No problem. There is a Pro 400 primer but it is sold to contractors, kept in the back room. I would doubt that is what he has. If it is the 400 primer then use that, it will work just fine. Just check the label and make sure the first coat is primer. Any of the major paint stores primers would work just fine.
Go Pitt!!!
Chuck
Old 06-11-2010, 04:02 AM   #12
chrisn's Avatar
Rewards Points: 496
Chris,
Go Pitt!!!
Chuck
Not sure which Pitt team you are rooting for but my son goes to Pitt, so I am becoming a Pittsburgh fan myself
Old 06-21-2010, 11:55 AM   #13
FYI what I have is Promar 400 Primer and not finish paint.
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 12:25 PM
How to remove paint from plastic? cevamal Painting 3 09-14-2009 09:44 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
new windows coming...need to paint Dusty Painting 1 11-01-2006 01:38 PM
