Paint Coming Off Hardie Siding - Painting - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 01:54 PM   #1
paint coming off Hardie siding
We have a new home that is six years old. After two years paint started coming off in spots on the west side of the house. This is the side that gets most of the wind and rain. The contractor repained the spots. The paint is S/W paint with a 30 year warrenty. They say if they used the wrong primer, on warrenty.
We are still having problem. What does the contractor need to do to correct the problem???
Jack Wardlow is offline   Reply With Quote
Old 04-23-2011, 02:44 PM   #2
Gymschu's Avatar
Rewards Points: 246
Wow, never heard of this happening on Hardie Plank. Painted my HP on my garage with SuperPaint from SW and it has looked great for 6 years. I have heard that HP had issues with the factory applied primer that caused dead spots in the finish coats........I don't know when that issue started to appear, but you might look into it.
Gymschu is online now   Reply With Quote
Old 04-23-2011, 08:46 PM   #3
Some hardie siding has a primer on it from the factory. Most manufacturers will require a primer over this factory primer to ensure proper adhesion. hadry siding is cementuous. The ph level is often what causes premature paint failure. A PQR could be performed by the servicing store to further research the specific issue. I would spot primer the peeling spots with a 100% acrylic primer then try to touch up the area with the original paint if any is left over. After 2 years it will be difficult to make the color blend perfectly so your contractor may have to paint up to the end of a wall or a joint in the siding. I would take a piece of the peeling paint to the store and have a PQR done. That's a good starting point.
Duration is offline   Reply With Quote
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
paint or stain weathered cedar siding daynat Painting 1 06-02-2009 11:03 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
new windows coming...need to paint Dusty Painting 1 11-01-2006 02:38 PM
