Paint Coming Of From Doors And Frames - Painting - DIY Chatroom Home Improvement Forum
Old 02-20-2008, 02:35 PM   #1
paint coming of from doors and frames
I have decided to paint doors and frames in my bedroom and sanded the frames first. What happened is that a layer of paint started to come out. The there is another layer holds pretty good but the top layer is now peeling. I don't know what is going on. My guess is the old owners of the house ( I recently bought the house) painted with water based on oil based paint. How can I be sure if this is the case and if that is the case what is the best and/or easiest way to solve the problem.
It is okay to just paint on top of the paint with a light sand?
np2008 is offline   Reply With Quote
Old 02-20-2008, 04:33 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
You can wipe the painted surface in question with Oops! or Goof Off!, or even better denatured alcohol
If the color wipes off, it's latex
If it does nothing, it's oil
But at this point, you've kind of got a mess, and you cannot "just paint over it" anyway
Regardless of why the paint is failing, the best fix is the same
Scrape an sand off any loose or questionable coating
Clean well
Prime with an oil-based primer
Top coat with a quality paint, preferable an enamel, your choice oil-based or waterborne
slickshift is offline   Reply With Quote
Old 02-21-2008, 12:38 PM   #3
First, get the door of the hinge and set it on a saw house and sand with 120 grit to open the paws in the wood, then dust away all the sanding and use a tach cloth to remove any extra dust, then prime and paint.
___________________
home interior painting
rk_king2004 is offline   Reply With Quote
Old 02-24-2008, 02:39 PM   #4
She'sapainter
get some solvent denatured or laqure thinner whip area then get green sand paper the latex paint won't roll as bad when your sanding for you will still have some paint left on the case work. I live in CA and we don't need to use oil as much as in the East Coast and so I don't recomned oil but water base primer So just prim and paint.
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
Old 02-24-2008, 04:17 PM   #5
Jack of Some Trades
Wood Butcher's Avatar
is it a quality door, or just cheap hollow masonite? sometimes you are better off just picking a new masonite slab door from one of the homecenter (about $30). You'll spend that half of that in sandpaper, chemical cleaners, primer, tack cloth... not to mention time and cleanup
Wood Butcher is offline   Reply With Quote
Old 03-06-2008, 04:36 PM   #6
Thanks everybody who replied.
The doors are low quality I can replace them but the problem is the door frames. I'm trying currently sanding them, putting an oil based primer and will put a water based paint on it. I hope this will work. If not, I guess I'll go ahead and clean all the paint on it and will do the work again.
I know taking my chance maybe is not a smart thing in this condition but currently I don't have much time to do a lot work on these doors and door frames. I hope I'll have enough time later if/when this proves to be a bad idea.
Old 03-06-2008, 06:03 PM   #7
Reminds me of when latex paint is brush onto a painted enamel surface with no primer or sanding or undercoat. Peels off with your fingernail like a piece of dead skin off a sunburned armed or leg.
End Grain is offline   Reply With Quote
white paint turning yellow victor Painting 40 11-13-2012 09:09 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
repairing damaged wood on older doors, frames, etc (peeling, chipped, etc) joeyboy Carpentry 9 10-03-2007 08:33 PM
Doors in a 1920's home samsays Remodeling 13 07-05-2007 09:50 PM
Peeling paint Lisalovespainting Painting 7 02-17-2007 07:52 AM
