Paint Colors - Painting - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 01:55 PM   #1
Paint colors
Hi folks!
Need some advice.
We are re doing our dining room.
I added chair rail.
I added arches to 2 doorways.
I added flexible casing around the 2 arched doorways.
There is 1 window with trim painted white.
And crown molding the same color as the ceiling, off white.
QUESTION:
Should the chair rail color match the door casing color?
What about window trim, based board crown molding color?
The lower wall half will be a dark taupe and a muted gold type on top.
Thanks so much!
rvrman is offline   Reply With Quote
Old 02-05-2011, 02:09 PM   #2
ltd
Rewards Points: 536
yep definitely all trim same color in a satin or semi gloss
ltd is offline   Reply With Quote
Old 02-07-2011, 01:15 AM   #3
Professional Painter
The chair rail should match the door casing color - it's considered trim. The window trim and baseboards are trim too. You want it to all look the same. Slight verations are not going to kill you, but I would try to keep them the same.
If you need more help, click on my
Thanks so much!
Last edited by Gary in WA; 02-07-2011 at 01:23 AM. Reason: As stated in our Advertising Rules, you may not post advertisements on our site unless your a local contracting professional
mattroefer is offline   Reply With Quote
Old 02-08-2011, 05:07 PM   #4
Colors?
Thanks for the help!
Off to get paint and supplies.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Paint color tone changing in colors richwill Painting 2 09-13-2009 11:10 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Paint recommendations and finish questions EJacobs Painting 2 09-03-2008 11:38 PM
faux paint colors KCpainter Painting 3 02-01-2004 07:03 PM
