Old 01-12-2013, 02:32 AM   #1
Paint/coat to solve stucco problem
Please advise on type and product of paint or coating that I should use on the exterior of my 1976 stucco house which has a lot of hairline cracks that leak during water testing?
I would like to keep moisture out of the house. Stucco covers not only the house, a coat also covers the foundation, going below grade to the ground and cement patio. It's unknown as to what extent the stucco coating on the foundation can wick up to the house.
We took off some sheet rock in two bedrooms and discovered rotted barrier paper and wet insulation. The suspected causes were long term water damage from 2 vents and a window, which have now been repaired/replaced. Drylok was painted on the stucco wall from the inside where the rotted barrier paper had been. However we could not seal everything, and some 2x4s remain in direct contact with the exterior stucco.
nanciann is offline   Reply With Quote
Old 01-12-2013, 06:39 AM   #2
Hi Nanciann, What you need is an elastomeric coating. Different companies have different products, and I believe SW has two or three, which you can discuss with the paint co for your needs. Be sure to read the link under PDS. You'll learn such things as two coats are required to block wind driven rain, to water"proof" it, and that it's not designed to block hydrostatic pressure, which means it's not spec'd below grade. Below grade would be a job for foundation guys.
http://www.sherwin-williams.com/pain...meric-coating/
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
Gymschu (01-14-2013), ToolSeeker (01-12-2013)
Old 01-14-2013, 10:43 AM   #3
Cracked stucco needs to be patched, prior to tocpcoating, even with elastomeric coating.
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
Wall meets Eave Stucco repair (pics) fourx Concrete, Stone & Masonry 0 06-18-2012 09:58 PM
New stucco over old painted stucco exterior Sandstone Remodeling 1 03-31-2011 05:26 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 08:07 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
