Old 10-06-2008, 05:14 PM   #1
Paint on ceiling in error
Son painted bathroom and did not tape ceiling edge. Paint on ceiling in multiple places. What are some recommendations to remove the paint? Thanks!
michjona is offline   Reply With Quote
Old 10-06-2008, 05:23 PM   #2
RippySkippy's Avatar
If it's dried I doubt you will have much luck removing it. Is the ceiling painted? Can it be touched up?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-06-2008, 06:47 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Removal will (most likely) not be possible
Touching up the ceiling is the SOP for this problem
slickshift is offline   Reply With Quote
Old 10-07-2008, 11:38 AM   #4
Thanks for your response. The ceiling is white and the room was painted a dark shade of pink. I may try using white primer to touch up the areas where the ceiling was painted.
Old 10-07-2008, 02:05 PM   #5
Most primers have insufficient hide to cover up a different color paint. (There are a few high-hide primers out there, but most aren't.) But in any case, there is no need to prime, just topcoat with paint (probably two coats.)
SirWired
sirwired is offline   Reply With Quote
Old 10-07-2008, 02:21 PM   #6
Thank you! That is a much better idea.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
