Paint Bubbling Up In Kitchen - Painting - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 10:15 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Paint bubbling up in kitchen
While repainting my kitchen in the house I bought, I noticed it is bubbling up in some spots. The walls were washed before painting as there was lot of greese everywhere. Could it be that some greese got soaked in so bad that cleaning made it stay? Was not me that cleaned (or painted for that matter) but I'm pretty sure the cleaning product used was VIM.
Old 08-10-2009, 04:33 AM   #2
Remodeling Contractor
What paint are you using? Did you prime? Best to prime with a sealing primer with these conditions.
Old 08-10-2009, 09:48 AM   #3
Wire Chewer
Rewards Points: 126
The paint is Moore Spec, and no we did not prime, imo we should have probably done the whole wall just to be safe. Only primed small spots where plaster was used.
Old 08-10-2009, 03:38 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
More than likely it is first coat of paint failing and the new paint on top of it pulls as it dries causing bubbles. If that is the case, priming probably won't help. Primer shrinks as it dries too so it can pull bubbles as well. They may go away and they may not. If they don't go away, pop one and see if it is a bubble all the way down to the drywall.
Old 08-11-2009, 04:54 AM   #5
macro01's Avatar
does the bubbles appear before you paint it or after?
macro01 is offline   Reply With Quote
Old 08-11-2009, 03:15 PM   #6
Wire Chewer
Rewards Points: 126
The appear after it dries.
Old 08-11-2009, 08:31 PM   #7
Tom3982s
Prime
I have had the same issue. For me a good primer seem to eliminate the issue. I have never had the problem again. The primer was the key for me.
I was not sure what caused my problem though...
Tom3982s is offline   Reply With Quote
Old 08-11-2009, 08:34 PM   #8
Wire Chewer
Rewards Points: 126
Too late now as the cabinets are already being installed, and the affected areas wont really be noticable, but I'll know for future to just prime everything to be safe. Would something like kilz pretty much ensure this wont happen?
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 10:23 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
What's a good price to pay to Paint Kitchen cabinets MTDAMON Painting 2 11-29-2008 05:34 AM
Need recommendation for type of kitchen cabinet paint MBScott Painting 10 09-08-2006 09:12 AM
kitchen paint color pj1 Painting 2 01-29-2005 06:36 PM
