Paint Bubbles After Plastering - Painting - DIY Chatroom Home Improvement Forum
Old 05-27-2008, 08:25 PM   #1
Paint Bubbles after Plastering
Hi,
I just finished doing some patch work with plastering on the drywall. Afterwards I started priming and noticed the paint had bubbles on the drywall. Any ideas as to why?
Thanks.
anthony9887 is offline   Reply With Quote
Old 05-27-2008, 08:37 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
How long did the mud have to dry before you started priming?
Sir MixAlot is offline   Reply With Quote
Old 05-27-2008, 08:45 PM   #3
I let it dry for 24 hours.
Old 05-27-2008, 08:52 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Which "plaster" and primer did you use?
How big/deep was the repair?
I suspect the repair was not fully dry
slickshift is offline   Reply With Quote
Old 05-28-2008, 07:58 AM   #5
I used premixed mud and a latex CIL paint primer. The wall had a dark colour. I applyed some spackling to fill in any holes on the previous colour that was there. The spackling was extended past the holes. Afterwards, I let it dry, then sanded until flat and the primed. It was more of fixing tiny holes in the drywall. 10mm. What is the proper procedure for using spackling?
Old 05-28-2008, 05:54 PM   #6
slickshift's Avatar
Sorry, you said it was plaster...that's got different issues
(It's really different stuff, spackle, plaster, joint compound [mud]...and that's important to mention when chasing down problems)
Which "spackle" was it?
A lightweight latex spackle?
Or one of the heavier ones?
It may have been the incorrect one for your project
Did it only bubble over the repairs?
Technically 10mm is pushing it for spackle repairs size-wise, but not pushing it that much...it shouldn't have bubbled for that reason alone
But depending on what product you used, it could have been
Old 05-28-2008, 07:04 PM   #7
Rewards Points: 918
Also, when applying over a painted surface these materials will take much longer to dry. Even though it is dry on the surface, down below the surface is still not fully cured. I'm still thinking moisture on this one.
Old 05-29-2008, 10:11 AM   #8
Rewards Points: 530
Originally Posted by anthony9887 View Post
Hi,
Thanks.
I'm a little confused here. Did you apply one coat of primer then notice bubbles? Prime and paint then notice the bubbles? One coat primer? One coat paint? How long between coats? Sounds like a moisture problem (not enough dry time) to me too.
Old 06-12-2008, 11:45 AM   #9
Another DIY Zombie
Rewards Points: 264
I came across a similar problem with my wall. It blistered upon the application of the 1st coat of paint. There were two coats of color-hiding primer. When the bubble was opened, and the paint was peeled, I was looking at a fresh drywall repair. The primer did nothing for the fresh JC that was applied (it was dry). In my case, it was a mis-match of materials.
javan is offline   Reply With Quote
BEHR Paint Problem Please advise PaintPro Painting 14 05-12-2012 11:15 PM
What's your "favorite" tip, when using "oil base" paint? Bobrobert Painting 15 01-17-2008 10:36 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
my painter did not fallow the contract jaskoo Painting 17 11-19-2006 01:21 PM
