Paint Brushes-Inbetween Coats? - Painting - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 03:32 PM   #1
Paint brushes-Inbetween coats?
I was told that in between coats you can wrap your brush with plastic wrap or aluminum foil. If its oil based you can stick in freezer & latex in fridge. Is this true?
fixnbreak is offline   Reply With Quote
Old 01-14-2010, 06:20 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 136
You can but I can still see no reason why. Plastic for latex, aluminum foil for oil will do just fine if wrapped air tight, no need for refrigeration and or freezing,IMO only.
Old 01-14-2010, 08:10 PM   #3
BJ
Plastic wrap
As long as you get an air tight seal the brush will be ready to go. That is unless you happen to leave it out in the hot sun, oops!
BJLower is offline   Reply With Quote
Old 01-14-2010, 08:17 PM   #4
WindowTreatment Installer
I wrap them in an old plastic grocery bag but I was told to keep in fridge as well, not sure why though.
bobtheblindguy is offline   Reply With Quote
Old 01-14-2010, 08:19 PM   #5
thanks for the replies, the reason I ask is that the primer I'm using is oil based, (painting my cabinets) theres not enough room in my place to prime all in one go, so i need to leave a day in between doing the cabs and then I figure i have room to do the doors in a day or two.
When I paint (this ones acrylic) , the can says i can recoat in 1 hour. hence my reasoning.
But if you have better suggestions im open to those to.
Old 01-14-2010, 11:28 PM   #6
Too Short? Cut it Again!
Personally, I clean brushes between uses.
Old 01-14-2010, 11:35 PM   #7
When I used to paint, I wrapped latex brushes with a damp cloth/rag a few hours and put them in a plastic bag if it was going to be longer. It keeps them nice and fresh. If you wrap an oil brush with an airtight plastic bag then it should be fine. I would only put it in the freezer if it's going to be days or months in between painting. I used to keep an oil roller in the freezer for ceilings for a long time without issue.
prbimaniac is offline   Reply With Quote
Old 01-15-2010, 06:23 AM   #8
chrisn's Avatar
Rewards Points: 136
The oil will melt the plastic, that is why you need the tin foil
Old 01-15-2010, 10:10 AM   #9
Thanks for that reminder.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
