Paint Brush Sizes? - Painting - DIY Chatroom Home Improvement Forum
Old 01-29-2014, 04:04 PM   #1
Rewards Points: 170
Paint Brush Sizes?
Its been a while since I last painted. What are the most used paint brush sizes?
2" for trim
1.5" for small touch up
and a 2.5" or 3" for larger surface areas?
HandyFrank is offline   Reply With Quote
Old 01-29-2014, 04:27 PM   #2
Rewards Points: 3,865
I think it is really a matter of preference. A guy that works for me every now and them prefers a 3" brush for cutting in and trim. For him it works. For me it would not.
I use 1.5-2" for trim and fresh touch up. Older touch up I might be using a model brush. 3-4 for large areas or exterior trim other than windows and doors.
Colbyt is offline   Reply With Quote
Old 01-29-2014, 04:29 PM   #3
Rewards Points: 14,026
Can you give use an idea on what your planning on painting?
I use a 2-1/2" sash brush for all my trim.
I know I'll get jumped all over but that's ok, I use a hot dog foam roller when painting jambs, stools, baseboard and casing to get the paint on faster, then tip out with the sash brush.
Old 01-29-2014, 04:50 PM   #4
Painting Contractor
Rewards Points: 171
I use a 2.5" for trim. I use a 3" for wall cut-in, sometimes 3" angle if there's a lot of stuff to cut around. I use a 2" for touch-ups. For doors, I paint the recessed areas with brush, roll the flat areas with a 4" roller and strike it with brush. 4" brush is good for exterior siding, soffit, etc.
VAProPainter is offline   Reply With Quote
Old 01-29-2014, 05:35 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
2 1/2 or 3 inch for everything. I own a few smaller brushes but hardly ever use them.
Jmayspaint is online now   Reply With Quote
Old 01-29-2014, 06:52 PM   #6
Gymschu's Avatar
Rewards Points: 942
Joe, why would anyone jump all over your for using a 2-1/2" sash brush? That's pretty much the standard "go-to" brush for most painters that I know. From painting trim to cutting in, it's the perfect tool IMO.
Old 01-29-2014, 07:05 PM   #7
Rewards Points: 170
Thanks everyone.
I'm going to be painting a 1/2 bath I am renovating that is going to have a bunch of trim and board and batten style wainscoting. Anyone suggest I roll the rails and stiles, or should I brush them? They are basically flat pine stock, no inside cap so I'm basically painting the flat surfaces.
Last time I painted my solid core doors I cut the routed design area, and then rolled the flat parts with a small foam brush and they came out great.
I have a brand new 1.5" straight brush, and 2.5" Angled Purdy clear cut brush. Probably grab a 3" and start from there.
Old 01-29-2014, 09:28 PM   #8
Rewards Points: 4,796
He was talking about the foam roller when he said that
jeffnc is offline   Reply With Quote
Old 01-29-2014, 09:30 PM   #9
The 1.5" straight brush is mostly worthless for me, except for odd jobs. The 2.5" Purdy will probably be your best friend.
I like putting paint on with a roller, but then getting the correct brush strokes with a brush. A roller gets paint on faster than a brush, and a brush makes it better looking IMO.
The Following User Says Thank You to jeffnc For This Useful Post:
Gymschu (01-30-2014)
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
