Paint Blisters - Painting - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 05:19 PM   #1
Paint Blisters
Doing a small remodel of a bathroom, the original finish was stipple on the walls. To get rid of that I first sanded them (probably 3-4 coats of oil base semi gloss), washed with TSP and then skimmed it with texture mud. A light sanding and 1 coat of Behr drywall primer and sealer. When I applied Kelly Moore interior eggshell latex enamel today, it raised a few small blisters in two different places. Is this because of the oil base underneath or insufficient primer, or ??
Malibujim is offline   Reply With Quote
Old 05-05-2009, 06:30 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Could Be...
Insufficient rinse of TSP (can leave a film if not rinsed)
Crappy primer (and that PVA is crap, especially in this tough situation)
Insufficient removal of contamination (bathrooms are the worst, every Glade anti-stink or Hair Spray sprayed leaves a film that is difficult to remove)
Incorrect primer (an oil/alkyd - based primer should be used over an oil paint job, it can then be coated with water-based topcoats)
High humidity (using the shower) before any/all steps can cure
A moisture problem that hasn't been fixed (moisture in the walls/ceiling)
slickshift is offline   Reply With Quote
Old 05-06-2009, 08:45 AM   #3
Rewards Points: 346
I am not sure what caused your problems but I have had similar problems in kitchens and baths for the reasons Slickshift mentions in the post above. For that reason I started using B.I.N., that hard to work with alcohol based shellac primer. I have not had a problem since. It is not really that hard to work with and I really like that it drys in minutes. Be sure to ventilate well when using B.I.N. as the evaporating alcohol can get to you. I do not think it would solve moisture problem but it seem to cover and stick to about anything. I keep a quart or more of alcohol and a couple hand for quick clean up and soaking brushes.
RegeSullivan is offline   Reply With Quote
Old 05-06-2009, 10:41 PM   #4
Thanks. I got a spray can of BIN, and I've been told to add a coat of Bullseye 1,2,3 primer after that. We'll see how that goes.
Old 05-11-2009, 11:48 PM   #5
The BIN didn't do it!! Soon as I applied the 123 primer the blisters reappeared, same as previous. After doing a little more reading at the Zinnser web site, I decided to try some Gardz. Don't know what's in it, but it worked. Let it dry 6 hrs, primed with 123 again and no blisters. Top coated the next day, and no more blisters.
Old 05-12-2009, 08:49 AM   #6
Rewards Points: 346
I am curious why you are you priming over primer. I never tried this but I could see where it could cause a problem especially if you are using two different types of primer.
I am glad to hear you got it to work out for you.
Rege
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
