Paint Bleeding Under Tape......why? - Painting - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 10:48 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Paint bleeding under tape......why?
I taped an area of my trim, and I pressed it really well, so that it would not bleed underneath but, yes, it did.
What did I do wrong? I'm not very happy , as it was dark brown meets white............
I am using the green coloured painters tape. I thought that this is the reason we use tape so that we can get a nice crisp line........
yummy mummy is offline   Reply With Quote
Old 02-11-2009, 10:11 AM   #2
Home Remodeler
Rewards Points: 164
I remove the tape immediately after painting..
mikey48 is offline   Reply With Quote
Old 02-11-2009, 10:41 AM   #3
(the original)
Rewards Points: 756
You're probably putting too much paint on with the first coat. If you put on a very light first coat and let it dry, it'll help seal the tape edge so the next coat doesn't bleed under. You can also seal the edge with clear poly first, let it dry, then paint, and you'll get a cleaner line. I prefer to freehand and use an edger in tight spots, myself, but it takes practice and a steady hand. As a general rule, multiple light coats work best, and you can always clean up the edge with a small art brush.
ratherbefishin' is offline   Reply With Quote
Old 02-11-2009, 10:48 AM   #4
I did put a heavier coat on, maybe that is why.
Old 02-11-2009, 06:48 PM   #5
Learning new stuff
Send a message via Yahoo to Ed.n.Wendy
Tape is very messy
After years of painting I've developed a pretty steady hand so I haven't used tape due to just that! What a mess to try and fix. If you feel you need a straight edge try using a level and drawing a line, then hold a wide mudding spatula (about 10") up to the line and paint. This works pretty well and easy cleanup. Not to mention how it saves time with no taping. Good Luck.
Ed & Wendy
Ed.n.Wendy is offline   Reply With Quote
Old 02-11-2009, 09:10 PM   #6
Thanks Ed and Wendy.
I am now doing it free hand. After a while, I have become pretty good at it.
I have touched up the other area by hand, and looks pretty good.
Old 02-12-2009, 05:12 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Yup...I'd expect that
You'd be wrong (contrary to what it looks like on the Home Improvement Shows on TV - those are for entertainment - not "how-to")
Painter's Tape is used to keep splatter off of surfaces, not to "cut lines"
One can not use tape then goob on the paint and figure the tape will give you a pro line...it just doesn't work that way
The only tape that doesn't bleed is Frog Tape (also green btw)
And it will lift any questionable paint underneath it also...so it's not to be used lightly or even on un-cured (less than a few weeks old) properly adhering paint
Tape is a tool, not a crutch
The best way to cut a line is with quality tools and products, and a steady hand
slickshift is offline   Reply With Quote
Old 02-17-2009, 11:09 AM   #8
Rewards Points: 83
She used frong tape so it seems... I don't find it to be any better than regular old 3M blue myself.
The only "trick" I can suggest if hand cutting is not working for you (I can't do it myself without the lines looking like a drunken monkey did it) is to tape and then using the same color as what is under the tape, paint the edge where the tape meets the "to be painted" surface.This will seal the edge to prevent capilary action from sucking paint under the tape. However, usually I thin this sealer coat with water quite a bit as I want it to just seal the edge. I generally do this with a 1" brush and just barely cover the tape edge.... and I put it on thin.... really thin... Let this dry and put down your real coat and pull the tape as soon as you are done. You can sometimes get away with letting things dry and pulling tape with flat paints, but anything with a sheen will tear.
Bubbagump is offline   Reply With Quote
Old 02-17-2009, 05:22 PM   #9
slickshift's Avatar
3M has a green tape for uneven surfaces
I prefer it to the blue (regardless of surface), but it is hard to find
It is not the same thing (by any stretch) as Frog Tape (also green)
It will bleed just the same if used in that manner
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
How do I tape wall to keep paint from bleeding Thru? loomis56 Painting 5 04-19-2008 03:14 PM
