Paint Bathroom Ceiling Questions? - Painting - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 02:17 PM   #1
Paint Bathroom Ceiling questions?
Hi I have several questions regarding painting of the bathroom ceiling. Sometime ago my mom got the bathroom repainted it's now an ugly light brown color including the room. Mildew has started to grow on the room I want to repaint it. Should I just wash the ceiling with diluted bleach, then paint it white using a bathroom/kitchen paint? Or should I rent a sander and sand off all the old paint from the ceiling then use something like zinsser cover stain and then paint over that? lastly should I just clean apply the primer and then the paint? Edit: Forgot to add not sure what the current paint is. I think it's latex but not sure
Hypochondriac is offline   Reply With Quote
Old 08-14-2010, 05:42 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 386
Clean with the bleach, prime with a good bonding primer( latex for me), cover stain will certainly work, but IMO is overkill, paint with you're bathroon paint.I would use these products.
Old 08-14-2010, 06:29 PM   #3
Thanks, for the info I also have some cracks in the pain and wall. I should just scrape them away and then use Spackle on it right? I started scraping, but the cracks seem deeper then I thought. In one case when I think I scraped to far because I reached a wooden plank or something similar. How is bear premium paint? A friend suggested I use a primer and then the what ever color semi-gloss bear I want
Old 08-14-2010, 07:38 PM   #4
DIY staff
Rewards Points: 7,174
Please, Stay away from Behr paint---It is a bad product--
Use the paint in Chrisn's picture--It is a joy to use.--M--
Old 08-14-2010, 07:46 PM   #5
Ok I won't get Bear paint. I will probably be using cover stain, as the primer. If my local place doesn't have zinsser perma white what's a good alternative?
Old 08-15-2010, 04:51 AM   #6
chrisn's Avatar
Rewards Points: 386
You will probably need to tape and mud the cracks.Use regular joint compound, not spackle.If you cannot find perma white use this
Bathroom Paint - Crying Sap? stevencrider Painting 4 08-12-2010 06:21 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
