#1 |
Paint in bathroom
I thought I would paint the bathroom ceiling as the paint was flaking off, so read the tin and it said to remove the peeling parts as I did this most of the paint came off, so I chipped most of it away so I could get a smooth area to paint. Now most of it has come off but how do I remove the other tough part as I don't want to paint half plaster the rest old paint... Please help as I really don't know what to do?
Ladylivingonherown |
#2 |
Paint in bathroom
Hi Nush, welcome to the forum. If the balance of the finish won't come off, no need to remove it. That's what spackle/joint compoud is for. I would give it a light sanding with 100 grit paper to smooth it a bit, then apply spackle to feather out the rough edges. It may take 2-3 thin coats to do so. Don't glob it on. After the coats are dry, sand them smooth with 220 paper. The give the ceiling a good dusting or wipe with damp rag. Apply one coat of a quality primer/sealer, then finish with two coats of a finish appropriate for a bathroom. Depending on the environment, an eggshell, satin, or semi, or a dedicated bath paint. Good luck and check back with any questions.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Paint in bathroom
Look for primer that says Bonding Primer on the can.
It will stick far better to diffacult surfaces. Is there a ceiling vent in this bathroom? If not that's the most likly cause of your paint peeling. |
#4 | |
Paint in bathroomQuote:
#5 | |
| Display Modes | |
| alligator cracking lead based paint in bathroom | protechplumbing | Painting | 9 | 11-14-2011 06:28 PM |
| Questions about Sherwin Williams paint for a bathroom | nitting | Painting | 2 | 03-28-2011 05:23 PM |
| Bathroom paint dilema | JamesTee | Painting | 8 | 02-03-2011 09:46 AM |
| Choosing paint for bathroom | CowboyAndy | Painting | 3 | 04-04-2008 05:49 AM |
