Paint In Bath Room Problems - Painting - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 03:05 PM   #1
Rewards Points: 258
paint in bath room problems
well i need some advice on what to do with this paint problem
redman88 is offline   Reply With Quote
Old 01-04-2013, 03:52 PM   #2
Rewards Points: 14,312
Looks like a moisture issue coming from above the ceiling to me.
Is it just the picture is that whole area near to the walls all yellow?
Old 01-04-2013, 05:03 PM   #3
Mr. Paint's Avatar
Small bubbling like that is usually moisture-related and most likely caused by using the shower/bath before the paint had a chance to cure.
Sand out the bubbles, spot-prime with a fast-dry primer like Zinnser 1-2-3 and refinish.
Be sure the room is well ventilated when using hot water,
The Painter's Paint Store where QUALITY is ECONOMY
Mr. Paint is offline   Reply With Quote
Old 01-04-2013, 05:14 PM   #4
Rewards Points: 258
only vent for this bath room is the window on the wall with the shower/bath tub. and that is yellow up there on the white paint
Old 01-04-2013, 05:20 PM   #5
#1 A bathroom with no powered vent will be nothing but trouble.
Make that a #1 priority to add a vent that exohost all the way to the outside.
Main reason it's no longer legal to have just a window in a bathroom.
Old 01-04-2013, 05:23 PM   #6
Mr. Paint's Avatar
That yellow is surfactant that normally dries into the film; it is like soap, which helps the oils and the water in paint coalesce together. It is moisture-related during the curing process. Its leaching out will not hurt the integrity of the film. It will wash off with clear water on a rag. Do it while it is fresh. It may recur until the paint is fully cured.
Is installing a ceiling light/fan that vents to the outside feasible? I bought a Panasonic fixture and it works great.
Old 01-04-2013, 05:26 PM   #7
Guywithskills
I agree with venting is priority, window or fan preferred (for a palce this wet, would book fan to light switch, when in use, fan is on). For registers, use aluminum, no paint, anodized preferred- more corrosion resistant.. Cheap. When register is nasty, replace. For paint on walls, prefer semi-gloss enamel.
Guywithskills is offline   Reply With Quote
Old 01-04-2013, 05:33 PM   #8
Guywithskills
Fan vent can be flex 3" aluminum run to where it can point out existing attic vent. I avoid protrusions through the roof, simpler, cheaper and one less protrusion to leak and work around and just a cleaner looking roof. I've seen guys that think everything has to go through roof where it is, they are mistaken and they have too many roof jacks, unsightly, expensive and more to maintain and keep from leaking. I will even run all plumbing vents together with appropriate slope and make just one 3or 4" vent through where possible. This is within code as well.
Old 01-04-2013, 05:48 PM   #9
Rewards Points: 258
*roflol*
not sure i can get to that end of the house
Old 01-04-2013, 05:50 PM   #10
Rewards Points: 258
i am hoping in 5 years i can replace the roof with a higher pitch. and move the ductwork inside the attic space and the inside ductwork into the attic as well
Old 01-04-2013, 05:50 PM   #11
Rewards Points: 4,796
I find that setup annoying, personally. Maybe you or your guests will too. If it's important, you can hook up a humidity sensing fan, although they're more expensive.
jeffnc is offline   Reply With Quote
Old 01-04-2013, 05:54 PM   #12
Rewards Points: 258
right now this is not about an exust fan, when i get to that point in my remodeling i will as for options about them.
Old 01-05-2013, 04:23 AM   #13
paper hanger and painter
chrisn's Avatar
Rewards Points: 616
[QUOTE=joecaption;1086363]#1 A bathroom with no powered vent will be nothing but trouble.
Main reason it's no longer legal to have just a window in a bathroom.[/QUOTE]
copy and paste this somewhere, it is easy,I believe you have written this wrong about 6 times this week, spell check is that ABC thing in the upper right hand corner
exhaust
exhaust
exhaust
Old 01-05-2013, 04:37 AM   #14
[QUOTE=chrisn;1086639]
exhaust
exhaust
exhaust
In Joe's defense I must add that his computer may not have that handy ABC thing in the corner. Mine doesn't.
But Joe...seriously.. everybody makes typo's from time to time, but its easy to see a certain painter is going insane.
He has tools ya know and personally I wouldn't take the risk that the spelling corrections may end up being painted somewhere.
Chris...while you are there will you please CONSIDER fixing DIFFERENT..
creeper is offline   Reply With Quote
Old 01-05-2013, 08:05 AM   #15
chrisn's Avatar
Rewards Points: 616
[QUOTE=creeper;1086641][QUOTE=chrisn;1086639]
Chris...while you are there will you please CONSIDER fixing DIFFERENT..[/QUOTE]
Really? I just assumed( I know) that this site was viewed the same by all.
Guess not Sorry about that. There are free spell checking tools for different browsers through.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
How should I paint this room? LeroyFrick Painting 8 10-30-2007 05:09 PM
