-   -   paint in bath room problems (http://www.diychatroom.com/f4/paint-bath-room-problems-168242/)
redman88 01-04-2013 03:05 PM
well i need some advice on what to do with this paint problem
http://i277.photobucket.com/albums/k...982/photo1.jpg
joecaption 01-04-2013 03:52 PM
Looks like a moisture issue coming from above the ceiling to me.
Is it just the picture is that whole area near to the walls all yellow?
Mr. Paint 01-04-2013 05:03 PM
Small bubbling like that is usually moisture-related and most likely caused by using the shower/bath before the paint had a chance to cure.
Sand out the bubbles, spot-prime with a fast-dry primer like Zinnser 1-2-3 and refinish.
Be sure the room is well ventilated when using hot water,
redman88 01-04-2013 05:14 PM
only vent for this bath room is the window on the wall with the shower/bath tub. and that is yellow up there on the white paint
joecaption 01-04-2013 05:20 PM
#1 A bathroom with no powered vent will be nothing but trouble.
Make that a #1 priority to add a vent that exohost all the way to the outside.
Main reason it's no longer legal to have just a window in a bathroom.
Mr. Paint 01-04-2013 05:23 PM
That yellow is surfactant that normally dries into the film; it is like soap, which helps the oils and the water in paint coalesce together. It is moisture-related during the curing process. Its leaching out will not hurt the integrity of the film. It will wash off with clear water on a rag. Do it while it is fresh. It may recur until the paint is fully cured.
Is installing a ceiling light/fan that vents to the outside feasible? I bought a Panasonic fixture and it works great.
Guywithskills 01-04-2013 05:26 PM
I agree with venting is priority, window or fan preferred (for a palce this wet, would book fan to light switch, when in use, fan is on). For registers, use aluminum, no paint, anodized preferred- more corrosion resistant.. Cheap. When register is nasty, replace. For paint on walls, prefer semi-gloss enamel.
Guywithskills 01-04-2013 05:33 PM
Fan vent can be flex 3" aluminum run to where it can point out existing attic vent. I avoid protrusions through the roof, simpler, cheaper and one less protrusion to leak and work around and just a cleaner looking roof. I've seen guys that think everything has to go through roof where it is, they are mistaken and they have too many roof jacks, unsightly, expensive and more to maintain and keep from leaking. I will even run all plumbing vents together with appropriate slope and make just one 3or 4" vent through where possible. This is within code as well.
redman88 01-04-2013 05:48 PM
*roflol*
http://i277.photobucket.com/albums/k...n1982/roof.jpg
http://i277.photobucket.com/albums/k...2/100_0357.jpg
http://i277.photobucket.com/albums/k...2/100_0355.jpg
not sure i can get to that end of the house
redman88 01-04-2013 05:50 PM
i am hoping in 5 years i can replace the roof with a higher pitch. and move the ductwork inside the attic space and the inside ductwork into the attic as well
jeffnc 01-04-2013 05:50 PM
I find that setup annoying, personally. Maybe you or your guests will too. If it's important, you can hook up a humidity sensing fan, although they're more expensive.
redman88 01-04-2013 05:54 PM
right now this is not about an exust fan, when i get to that point in my remodeling i will as for options about them.
chrisn 01-05-2013 04:23 AM
[QUOTE=joecaption;1086363]#1 A bathroom with no powered vent will be nothing but trouble.
Make that a #1 priority to add a vent that exohost:furious: all the way to the outside.
Main reason it's no longer legal to have just a window in a bathroom:eek:.[/QUOTE]
copy and paste this somewhere, it is easy,I believe you have written this wrong about 6 times this week, spell check is that ABC thing in the upper right hand corner
exhaust
exhaust
exhaust
creeper 01-05-2013 04:37 AM
[QUOTE=chrisn;1086639]
exhaust
exhaust
exhaust
In Joe's defense I must add that his computer may not have that handy ABC thing in the corner. Mine doesn't.
But Joe...seriously.. everybody makes typo's from time to time, but its easy to see a certain painter is going insane.
He has tools ya know and personally I wouldn't take the risk that the spelling corrections may end up being painted somewhere.
Chris...while you are there will you please CONSIDER fixing DIFFERENT..
chrisn 01-05-2013 08:05 AM
[QUOTE=creeper;1086641][QUOTE=chrisn;1086639]
Chris...while you are there will you please CONSIDER fixing DIFFERENT..[/QUOTE]
Really? I just assumed( I know) that this site was viewed the same by all.
Guess not:whistling2: Sorry about that. There are free spell checking tools for different browsers through.:yes:
