Paint For Basement Wall - Painting - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 08:19 AM   #1
Rewards Points: 39
Paint for basement wall
Our new basement to us is in need of paint. The previous owner left some less than desirable spray paint art works on the walls.
The walls are stone (1915 house), but were cover with concrete at some point. On top of the concrete is a white paint. Both the concrete and paint are in great shape without flaking or chipping. The basement has been dry for us and does not show any evidence of water issues.
What type of paint should be used? Would primer and paint work best?
Attached are pictures of the wall and the only place I could find chipped (to show layers).
KansasCity is offline   Reply With Quote
Old 07-30-2013, 10:45 AM   #2
Rewards Points: 5,974
I have had really good luck with the Sherwin Williams masonry line LOXON.
Old 07-30-2013, 11:05 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
Tool- Loxon is a great masonry product, but because it already has paint on it, wouldn't that be overkill?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-30-2013, 01:24 PM   #4
It has been a while since I have used it. But don't they have just a paint in that line, not just the conditioner. Maybe I misspoke and am thinking of something else.
Old 07-30-2013, 01:46 PM   #5
You're right- Loxon is a masonry paint. But I thought it was mostly effective on raw cement so it could penetrate a little, and still breath- but once coated, almost any latex would work.
Not enough use with it myself- But I don't thing the OP would have any problem using it. The main thing about a wall like that is some humidity will try and pass through it because it is a very porous wall, and if you seal it too tight the moisture will pop the paint off. So a breathing paint is best.
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (07-30-2013)
Old 07-30-2013, 05:35 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
So what's the verdict?
My own walls are the same thing and as long as there is no moisture present, I just paint mine with normal wall paint and 123 or in my case Fresh Start,as a primer.
The Following User Says Thank You to chrisn For This Useful Post:
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Help getting paint off block wall butchbs1985 Painting 4 06-09-2011 08:20 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
