Old 02-13-2010, 05:33 PM   #1
paint banister with melamine?
Hi, I had planned on just sanding down our banister (currently is wood with stain) painting with primer and then white latex paint. A friend of mine suggested to do a light sand, then paint with melamine, then to paint with latex. We want a white finish. I've never painted with melamine, and he seems to think it'll save a lot of time because we'd only have to light sand rather than sanding right down to the wood. Any thoughts?
lenster007 is offline   Reply With Quote
Old 02-13-2010, 06:41 PM   #2
Finisher
Why would you paint with melamine and topcoat with latex? Makes no sense to me.
Sand to 120. Prime with oil (zinsser cover stain will work) and paint with latex. Done.
Rcon is offline   Reply With Quote
Old 02-19-2010, 02:48 PM   #3
sdsester's Avatar
Me either. Melamine has its place but not for your application. And it chips easily. I certainly would not paint over it with a latex acrylic. Once you use melamine you are more or less committed to it.
All that said, factory mixed white urethanes might be a possibility but they chip too. Some of the new nano finishes with silicon are nice but really expensive.
I would stick with nice Ben Moore or Sherwin Williams latex acrylic.
sdsester is offline   Reply With Quote
Old 02-19-2010, 09:48 PM   #4
jlhaslip's Avatar
use zinsser primer and two coats of melamine
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 03-07-2011, 11:23 AM   #5
I painted my bathroom counter top with white melamine and want to repaint it...can anyone tell me what the procedure would be and specifically...because I used melamine, do I have to use it again? I don't like painting with melamine..its so thick.
KarenRB53 is offline   Reply With Quote
Old 03-07-2011, 11:34 AM   #6
Painting Company, NY
housepaintingny's Avatar
I would lightly hand sand the railing, wipe it down, prime it with Sherwin Williams Bonding Primer, apply two coats of Sherwin Williams Pro Classc enamel
housepaintingny is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
