Paint Aluminum Siding-first Time - Painting - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 09:46 PM   #1
Paint aluminum siding-first time
I had my 40 yr old white aluminum siding pressure washed today and now I think it needs painted to look good again. There are this graish spots in the finish now. I hope all the chalking is gone. What is the easiest, cheapest way to paint it white again? No sprayer here, only a brush/roller. Would KILZ seal it? Can I leave KILZ as a top coat? I did that on a wooden shed last summer and it still looks good. Does the siding have to be etched? Should I use "emalsa bond" the paint?
Any help is appreciated.
NFOHIO is offline   Reply With Quote
Old 07-26-2011, 11:03 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
i would use Sherwin Williams DTM wash primer with two coats of of DTM primer/finish. this system is extremely durable and covers very well. the wash primer only needs to be applied at .7 mils dry film thickness, so it will cover over 300 sqft per gallon. SW claims that the DURATION will cover aluminum siding too. ive alway felt that an etching primer is needed to bond to bare aluminum. lots of surface prep is needed to coat aluminum properly.
mustangmike3789 is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Painting aluminum siding cherry_560sel Painting 27 04-25-2011 02:35 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
