Paint For Aluminum Siding - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 03:48 PM   #16
Gymschu's Avatar
Rewards Points: 1,024
Believe it or not many times I have used a Whizz 6" roller to do aluminum siding. It holds a lot of paint and has an edge to it that gets the underside of the siding. It has a bit of a learning curve to it in that you have to learn to load it up properly and be a bit gentle when getting the underside of the siding. If you're not comfortable with that, any polyester blend 3/8 or 1/2 roller cover works fine. I also like the contractor grade golden eagle from Purdy that is sold in most Lowe's stores.
P.S. I get very little orange peel when rolling aluminum siding. In fact, if done properly, it actually will look like you sprayed it on.
Gymschu is online now   Reply With Quote
Old 05-29-2013, 04:54 PM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
Originally Posted by rayf01 View Post
Everyone keeps saying a roller is perfectly fine and the paint Is good at leveling. I was considering buying a sprayer for 80-100 at home depot and using my compressor too.
you will have to back roll it anyway, so why spray?
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (05-29-2013)
Old 05-30-2013, 08:14 AM   #18
So rolling, do I need to roll the entire length of the panel At once or can I do it in vertical sections? I don't have scaffolding is the problem some can't walk the whole length of the wall up high.
rayf01 is offline   Reply With Quote
Old 05-31-2013, 02:04 AM   #19
Anyone on the last comment?
Old 05-31-2013, 05:25 AM   #20
Jmayspaint's Avatar
Rewards Points: 534
Doing it in vertical section will create visible lap marks where the sections meet. If at all possible, go the whole length of the panels. This can be tricky up high I know.
If you have to do it that way up high. Try to minimize the overlap from one set to the next. Anywhere you paint back into dried paint will show. The less glossy the paint, the less it will show. Lighter colors show laps a little less too.
Lap marks tend to show up more over time also. As the paint cures, and then starts to fade a little, they look even worse.
Jmayspaint is online now   Reply With Quote
Old 05-31-2013, 06:01 AM   #21
Gymschu's Avatar
Sometimes you have to roll vertical because the aluminum has warped/cupped a bit, but, mostly you go the length of the siding. Take just 2 or 3 sections of siding at a time. Any more and you will get obvious lap marks.
Old 06-02-2013, 03:41 AM   #22
Guys,
How long do you think I can wait from the time I pressure wash the siding to actually painting it? I'd like to pressure wash it this weekend, and start painting next weekend. Likely do a little priming in between.
Old 06-02-2013, 04:01 AM   #23
chrisn's Avatar
Rewards Points: 614
Guys,
that would be fine
Old 06-02-2013, 09:19 AM   #24
Rewards Points: 240
good thread. as i want to paint my gutters, soffit and facia. one of these days.
Fix'n it is offline   Reply With Quote
Old 06-02-2013, 09:44 AM   #25
Jmayspaint's Avatar
Rewards Points: 534
Guys,
That should be fine, but aluminum in the sun can chalk up quickly. If your using an additive to help the bond, its not as much of an issue.
Maybe just check the siding in the sunny areas right before you paint to make sure they haven't re-chalked.
Old 06-02-2013, 10:42 PM   #26
Everyone, thanks for all the help so far. I secured the loose panels today, and filled any holes. Washing early this week, then spot priming and hopefully painting come next weekend, crossing my fingers on the weather.
Hoping to be able to paint it in one weekend.
A Home Depot/Behr paint experience jeffnc Painting 31 05-25-2013 11:14 AM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
Preventing rot in cedar siding.. observations and questions before paint 240sx4u Painting 3 11-03-2008 07:42 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
