-   -   Paint for aluminum siding (http://www.diychatroom.com/f4/paint-aluminum-siding-180747/)
rayf01 05-28-2013 10:06 PM
I was just at the Sherwin Williams store and they recommend the resilience over the A100 for aluminum siding. Any issues with that?
joecaption 05-28-2013 10:08 PM
My local Sherwin Williams and there web site suggest Duration or Super paint.
rayf01 05-29-2013 03:00 AM
I am going to be rolling it on and brushing. I have been reading that Resilience or Duration are hard to work with and can dry very fast? However they seem to cover better than A-100?
Im so stumped at what to choose...
chrisn 05-29-2013 04:29 AM
either will work fine, I would go with the resilience
Gymschu 05-29-2013 07:43 AM
Any of those paints are fine. Personally, my experience with SuperPaint on aluminum siding is excellent. Last year I used some Emerald and it also turned out great, but wasn't as easy to apply as SP.
joecaption 05-29-2013 08:19 AM
A100 in my opion is a builders grade paint, only has a 15 year warrenty.
If you looking to sell and just want something painted it will work.
Super paint comes with a life time warrenty, cost more to buy but worth it.
http://www.sherwin-williams.com/home...oatings/paint/
Having to go back years later and paint it all again just to save a few bucks now does not make since to me.
Jmayspaint 05-29-2013 08:26 AM
Resilience has the advantage of being more moisture stable during application so the threat of rain is less of a big deal when your painting. And it's a good quality paint.
The main thing will be to make sure the aluminum is clean, and free of chalk. On a sound surface, any of your choices will work good.
TarheelTerp 05-29-2013 08:28 AM
What prep is required on the aluminum?
(ps: the paint itself is always the least expensive portion of a quality job)
Jmayspaint 05-29-2013 08:46 AM
Generally a good cleaning will suffice. Run the palm of your hand over the surface. if chalky residue sticks to your hand, that residue will new to be removed or stabilized before painting.
Aluminum is bad to chalk, especially if its never been painted. I have seen several disastrous paint failures caused by painting over chalk. The paint will bond with the chalk instead of the surface, and literally fall off over time. There was a recent thread where this exact thing happened to someone.
Pressure washing is ok, aluminum is pretty fail safe as far as washer damage, but pressure washing alone often won't remove all chalk.
Scrub the surface with a soft brush, along with washing with a pressure washer, or just a garden hose. The scrubbing is the key. If you have chalk, it will look like watery milk as it washes off the house. After washing, do another palm test to make sure all the chalk is removed.
I've seen chalk so bad that even after thorough wash/scrub some still remains on the surface. There are also additives that help paint bond to chalky surfaces. 'Emulsabond' is the most common one that I know of.
My personal favorite for dealing with chalk is 'Seal Krete Original' it can be used as an additive or as a primer to stabilize chalk. But it can be hard to find.
Good luck!
rayf01 05-29-2013 09:11 AM
Resilience it is. Picking it up today, 40% off. Anyone recommend the best roller to get from them for aluminum siding application?
Matthewt1970 05-29-2013 09:39 AM
Good luck!
We paint a lot of alluminum siding around here and every company I have ever worked for swears by emulsabond. It really is the cat's meow for making paint stick to chalky surfaces.
Matthewt1970 05-29-2013 10:06 AM
n/m......
rayf01 05-29-2013 01:00 PM
Any specific roller that you guys recommend I use from Sherwin? I was also going to use a brush for the horizontal lap joins and then just roll over..
Matthewt1970 05-29-2013 02:53 PM
Probably a 7" with a 3/8 thinkness but do you really want the orangepeel texture a roller would leave?
rayf01 05-29-2013 03:01 PM
Everyone keeps saying a roller is perfectly fine and the paint Is good at leveling. I was considering buying a sprayer for 80-100 at home depot and using my compressor too.
