Old 10-11-2006, 12:49 AM   #1
Painiting a Wooden Ceiling
This is my first post.
We have a wooden ceiling with wood beams in the downstairs area of our house, which also has stone walls.
The ceilings and beams are a darkish varnished colour the wood inbetween the beams are like tounge and grooved about 8cm wide.
We would like to paint the wood between the beams white, which we are sure will make the place look brighter, as anyone done this if so what is the best method to use.
Susie
Susie is offline   Reply With Quote
Old 10-11-2006, 06:23 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
Sand with 180 grit to scuff up the surface (not sand the finish off)
Prime with a shellac-based primer/sealer
Lightly sand with 220
Paint
It'll need two coats
Use a high quality paint, or it'll need three or more
slickshift is offline   Reply With Quote
Old 10-11-2006, 08:15 AM   #3
Painting Contractor
Susie
Yes, I've done this....
Your going to want to pick up some painters tape (2-3") and tape off those beams where they meet the ceiling, first thing. You can then use either a brush or mini-roller right up against, to make it easier for you, and use the brush where the wood meets. (As Slick said) sand, and I'd like to add, make sure to wipe real clean. And for the sealer, I recommend a zinsser product called BIN (sold at Sherwin, Hardware stores, etc.) It's a bit smelly, so be prepared.
Actually, I would just go to Sherrwin and grab everything you need-you'll get good quality products, that will last much longer than this job. Ask them for their recommendations on your supplies.
"The measure of success is not whether you have a tough problem to deal with, but whether it is the same problem you had last year". ~ John Foster Dulles
Paintguy26 is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
Cathedral ceiling ventilation dpreznik Roofing 2 10-31-2006 11:18 AM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
