Pain A Basement Floor With This On It? - Painting - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 11:03 PM   #1
gruntman's Avatar
Rewards Points: 79
Pain a basement floor with this on it?
I want to paint my basement floor and walls. The owner before me put down this piece of floor in a corner of the basement. It looks like squares of linoleum with something used as a base. How do you get this stuff off? The prev owner added something to level the floor near the finished part of the basement as well. Any suggestions?
Pain a basement floor with this on it?-img_6270.jpg   Pain a basement floor with this on it?-img_6271.jpg   Pain a basement floor with this on it?-img_6272.jpg
gruntman is offline   Reply With Quote
Old 01-24-2011, 01:36 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 300
Ice scraper for the tile, be careful, it is almost certain to contain asbestos.
chrisn is online now   Reply With Quote
Old 01-24-2011, 10:10 AM   #3
After you have removed the tiles, clean the concrete with an etcher (like muriatic acid). Be careful with this product and make sure you have good ventilation.
once the surface is dry, vacuum up any dust and debris so the surface is clean.
I recommend using a good 1 part or 2 part floor epoxy paint. The 1 part product is easy to apply, and will dry very hard when it is cured. The 2 part epoxy is a "heavy duty" product that dries as the chemicals mixed react to one another. The 2 part epoxy cures out to be one of the hardest paint coating available.
As always - follow the manufacturer's instructions and have fun.
HDPaintPro is offline   Reply With Quote
Old 01-24-2011, 06:35 PM   #4
gruntman's Avatar
Rewards Points: 79
Asbestos in tile? Is it safe for me to do myself?
Old 01-25-2011, 04:50 AM   #5
chrisn's Avatar
Rewards Points: 300
Wear a good dust mask
Old 01-30-2011, 12:13 PM   #6
I have been doing a lot of research on asbestos lately, and I would stay away from it if I were you. We bought a house recently that has a lot of asbestos tile in the basement. We have contracted a consultant and the tiles will be removed by professionals.
Suggestion: Call up a company that does asbestos abatement in your area, and ask for someone to come take a look at the tiles. Sometimes they can tell just by looking at it. They do this for free. If they cannot tell you either way, ask them to recommend a lab to test a piece of the tile. Wet one of the tiles and get a piece of it. put the piece in a plastic bag, seal it and take it to the lab. We paid US$25 for the test. If you have children, keep them away from basement.
If it comes back positive, let the professionals deal with it.
Hope this helps.
Isabelbr
Isabelbr is offline   Reply With Quote
Old 02-11-2011, 12:29 PM   #7
gruntman's Avatar
Rewards Points: 79
I already took up a few of them. They came up pretty easily. There seems to be some type of tar underneath. Any suggestions on what to do with that? can I just paint over it?
Old 02-11-2011, 04:13 PM   #8
Super Master Painter
Ole34's Avatar
I had the same issue with my basement so I just did 2 coats latex semi-gloss...............and its been 4 years and no problems other than normal wear an tear............just get as much of that adhesive up as possible then 2 coats latex , NO primer is needed, only book taught painters use primer on masonry...........if you needed to prime masonry then we wouldn't have such a HUGE graffiti problem now would we? it would just fall of because it wasn't primed right??? lol..............you ever drive around and see somebody's name painted with a brush on a bridge or something??? usually says something like '' I love tina 4-ever'' lol well that **** will stay on there forever too ............look at it this way, dump red latex paint on your driveway and watch how long it stays there with out being PRIMED first .....you would be renting a power washer asap and still might not get it all off if it cured long enough ..........
heres one coat over the adhesive....notice that black spot under the compressor ??? thick ass glue lol ...........but it coverd on the 2nd coat...
Ole34 is offline   Reply With Quote
Old 02-11-2011, 04:14 PM   #9
Ole34's Avatar
delete...........
Old 02-11-2011, 04:23 PM   #10
Ole34's Avatar
this is 2 coats latex ............to the right of the dog there is some small problem areas were the paint lifted off the adhesive but just touch them up and eventually the paint will lock down tight as it cures..............best thing to do is 2 coats latex then next year add a third coat of latex............good to go then........this is what i did so if you dont feel comfortable doing it then DONT, im not forcing you but my way cost about $50 (if you get the paint) ...$30 for me
Old 02-11-2011, 04:37 PM   #11
Ole34's Avatar
ok this pic is from over the summer..................look at the floor !!now keep in mind a lot of what you see is DIRT/DUST cause i run my lathe down there and table saws etc etc ..........thats 2 coats latex semi-gloss 4 yrs ago and still looks good and i beat it to hell an back trust me .............it needs another coat now cause its showing its age but i dont feel like doing it ...............if it aint broke .......dont fix it
its important to get most of the glue off ( i didnt care, just left it there)..........see what happens is the glue is always there so when the paint wears off from traffic the glue will show through so get most of it off and you wont have any problems
Old 02-11-2011, 05:24 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OH MY GOD
THE SKY IS FALLING
THE SKY IS FALLING
TAKE COVER IMMEDIATELY!!!
What you have there is likely commercial grade VAT (vinyl asbestos tile). The tile does contain some asbestos. The black adhesive is "cutback" adhesive and it also contains asbestos. If you don't sand it, or grind it, or eat it, or suck on it, there isn't an issue. You as the homeowner can remove it and scrape up what adhesive you can, you won't get all the glue up. Bag the spoils and throw it in the trash. All states allow a homeowner to remove and dispose of that stuff. If it is coming up easily all the better.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
gruntman (02-14-2011)
Old 02-13-2011, 10:20 PM   #13
Echo Bud Cline. My father worked around and removed asbestos for a long time for a large electric utility and though he has been retired for twenty years, he still gets tested for that and for radiation damage from nuke work every year by the company. Nothing. I've breathed a pound or two of it myself. If most chemicals and toxins were as harmful as they claim, there would be no old painters. They have to keep us hysterical so they can save us. Did anyone remind OP of extinguishing pilot lights if he decides to use a two part epoxy in HIS BASEMENT. Bombs away! Follow Ole's advice and get a good latex floor enamel.
The Following User Says Thank You to jsheridan For This Useful Post:
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
How best to dehumidify basement? peleliu HVAC 0 07-27-2009 09:55 AM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 06:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
