Outside Application - Painting - DIY Chatroom Home Improvement Forum
Old 02-23-2014, 09:14 PM   #1
Rewards Points: 528
outside application
ill be putting final coat of latex based paint on a wood fence tommorow when outside temps are 55 -60, as done with primer a day ago, and first coat today. .Does the fact that outside tempts will be 29 at night but 50ish in day play a factor in curing properly? in 2 more nights it will be down to 18,26 ,but i have had good tempts when i applied it .Humidity is low and about 6 -7 hours of sun on it in day.
I have to get this done and its rare to have had this many good days to have been able to clean it prime and paint it before weather changes back..im not sure if its the low temp resisitant paint but i will look at that also.its benjamin more.
Any info is appreciated
hidden1 is offline   Reply With Quote
Old 02-23-2014, 10:19 PM   #2
Gymschu's Avatar
Rewards Points: 460
Most paint companies make low temp paint. Hopefully you have used a low temp paint. Personally I don't like to be painting anytime the temps are gonna be below freezing at any point in the drying/curing process. It's just not worth the risk. That being said, if you have to get it done, well, you have to geterdone!
Old 02-23-2014, 11:04 PM   #3
I look outside my door to 6' high snow piles. Must be nice.
Danahy is offline   Reply With Quote
Old 02-24-2014, 07:00 AM   #4
Rewards Points: 5,974
I think you need to have short work days so the paint will have a chance to at least dry some before the temp falls too low also a fast dry paint would help. I don't know if adding Japan dryer to the paint would help or not maybe Ric will help.
Old 02-24-2014, 07:04 AM   #5
Gymschu's Avatar
Rewards Points: 460
I think he's using a latex paint, Toolseeker.
Old 02-24-2014, 07:16 AM   #6
Sorry it's early no coffee yet. LOL
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (02-25-2014)
Old 02-24-2014, 10:47 PM   #7
Rewards Points: 528
I got it painted mid-later afternoon .I didnt see anything on can about lower tempts though.it will get down to 34 do you think it will bond/adhere correctly?
its latex acrylic exterior "Spec" paint from BM.
Thanks for any suggetions.
Old 02-25-2014, 03:42 PM   #8
Rewards Points: 394
Colder temps slow the cure, even though some top quality products for exterior cure down to 35 degrees F. If the product is tinted , especially dark, it slows down the cure even more. Your window is shorter, and the probablilty of blistering and peeling may happen, maybe not.
Will22 is offline   Reply With Quote
android application? Toller Site Help and Suggestions 8 05-10-2013 09:46 AM
What Electric Motor For This Application? abrogard Electrical 8 02-11-2012 10:29 AM
self sticking tiles - wall application peter_d_holmes Tiling, ceramics, marble 12 03-13-2011 06:18 PM
Using Cellulose Insulation, right application? fishmanflats Building & Construction 7 08-27-2008 09:32 AM
Knock down application tips needed gmhut Painting 1 07-31-2008 10:30 PM
