Outdoor Fence Mural - Painting - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 10:17 PM   #1
Question
Outdoor fence mural
We are attempting to put up plywood along the inside of the two horizontal supports on our fence to paint a mural. It will be about 2' high and run 82'. We plan on painting with our children and would like the piece to last a long time, preventing warping, peeling and fading as long as possible.
How do we treat, paint and seal regular plywood? Would an oil based primer, latex exterior paint and a clear waterproof/UV resistance sealant work? Any other suggestions?
Thank you so much for your time and insight!
lovejoywisdom is offline   Reply With Quote
Old 06-02-2010, 10:29 PM   #2
You would need PT or Marine grade plywood
Reg plywood will fall apart
Where are you located ?
Old 06-03-2010, 07:36 AM   #3
Thank you for your response! I'm in North Dakota. Will paint stick to treated wood? Thanks again!
Old 06-03-2010, 09:38 AM   #4
I was hoping a painter would respond with some advice
PT & Marine grade are painted, possibly oil based primer is your best bet
The Following User Says Thank You to Scuba_Dave For This Useful Post:
lovejoywisdom (06-03-2010)
Tags
exterior paint , fence , mural , plywood , sealant
Nursery mural - how to paint even black lines? Prangley Painting 25 10-05-2009 03:41 PM
