Old 05-11-2008, 07:25 AM   #1
Orange Peel Texture Help please
Ok, so I've just recently finished repairing and re-moding some walls around the house. The walls are orangepeel and I am having a hard time finding how to match the texture.
I've tried a can of "spray tex" idustrial orange peel but the texture turns out much finer. I need bigger blobs in my orange peel! Any reccomendations will be greatly appreciated!
Thanks!
Nick
kalaniwavo is offline   Reply With Quote
Old 05-11-2008, 09:27 AM   #2
You need a texture machine.25.00 a day and you will be able to match the orange peel you have.With a texture machine you have a constant pressure,which equates to the same consistency of texture being applied. Here is a link to show you what I am talking about.
http://www.ur.com/index.php/equipmen...id=2175&page=4
mark942 is offline   Reply With Quote
Old 05-13-2008, 11:26 PM   #3
Pro Painter
You can mix the mud yourself and "spatter" it on with a very course brush, like a wall paper paste brush.
joewho is offline   Reply With Quote
Old 05-14-2008, 07:41 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Did you try adjusting the nozzle of the Homex Orange Peel sprayer can? The nozzle adjusts to give you large spatters to more fine spatters.
- Build Well -
Old 05-17-2008, 05:45 AM   #5
Floating in the Gulf
Ok, so there are two possibilities... and it sort of depends on how much wall you need to do.
1) If you have a lot of wall to do, you can either borrow or rent a texture sprayer... I don't know if Home Depot has em, but a lot of smaller place do. If you already have an air compresser, I have actually seen the hoppers for sale for $50 or so, for the cheaper type.
2) If the area is pretty small, you can get one of those straw hand brooms, remove some of the straw, dip it in your drywall mud, and "throw" it at the wall. Make sure you don't throw it at an angle, or it will probably look weird. (Unless the original texture was sprayed at an angle.)
I've never had the spray can stuff work well for me. Always looked more like that ceiling popcorn than orange peel. Maybe my technique was bad.
In both cases I would recommend that you practice on a spare piece of drywall before you try to do a whole room. But one of the nice things about DIY texture is you can always gently scrape it back off if it isn't working out for you on the first try.
Good luck!
krankykitty is offline   Reply With Quote
Old 05-17-2008, 09:58 PM   #6
remodeling pro
Sounds like what you have is more commonly called a splatter, rather than orange peel, which tends to be a finer, more consistent finish. You need either a hopper and compressor, or a texture pump for this, like krankykitty says. Matching texture is an acquired art, so you might consider seeing how much a pro would charge you for the job.
troubleseeker is offline   Reply With Quote
Old 05-18-2008, 08:32 AM   #7
For one thing, it is not easy to completely "match" a new orange peel texture to an existing orange peel texture surface. That difficulty, is the case with the pros, ..... let alone DIYer.
When we have to do "patch-type" orange-peel repairs for clients, we will state in our proposals, that the only way to guaranty a seamless, consistent, uniform pattern (new "with" old), is to re-texture the entire area, or the entire length of wall, or the entire room's ceiling.
(It is much like auto repair. Example: A repaired and painted fender. Sometimes, you have to paint the whole car over, in order to get the color the same).
The cans are fine for simple smaller wall patches. However, if you are attempting to create a "close-to" or an "exact" match, then you would have to go with a sprayer. Use the correct nozzle, the correct compound consistency, and consider the possibility of having to re-coat large areas , in order to get the orange peel spatter to a uniform pattern.
Remember that with a repair where you have to match a new surface-finish to an existing surface-finish, always do some prior test runs, on same materials, in order to adjust and fine tune your method, prior to the actual application.
Good Luck.
- Build Well -
Old 05-18-2008, 03:51 PM   #8
Drywall and Painting Pro
Sir MixAlot's Avatar
Using the cans can also become quite pricey if you have alot of areas to do @ $10+ per can.
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 05-18-2008, 04:02 PM   #9
I just found this Orange Peel photo in my collection of job photo's.
Is this what your Orange Peel looks like? Keep in mind this is very cose-up.
Checkout some of
Old 05-22-2008, 12:52 AM   #10
Pro Painter
This is an issue for me as well. As a pro, the cans just aren't going to cut it. But being a painter, not a texture/drywall installer, I can't justify buying expensive equipment. There are some neat tools out there besides a sprayer. There's a small, hand pumped unit that looks like the old time bug sprayers. Canister with a pump handle on one end and a nozzle on the other.
Another tool I saw, but can't find for purchase is a small box with a crank on the side. It's filled with compound, turn the crank and thick wires throw the splatter out the "shute". Saw both on commercial jobs where I was on the touch up crew. Anyone know of these items?
Old 05-25-2008, 06:39 AM   #11
diyseattle's Avatar
The best way to cover dry wall repairs is to skim coat the entire wall first and then re-texture. That way you'll have an even surface and the walls will look new again.
diyseattle is offline   Reply With Quote
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
Pock marks in (drywall) orange peel texture RickC Building & Construction 2 01-14-2008 09:54 AM
Same Ceiling: orange peel and knockdown sir_rob Painting 17 10-01-2007 05:28 PM
Knockdown ceiling : My walls are orange peel.. Arkanoid Remodeling 4 08-07-2007 01:23 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
