Old 01-17-2011, 05:01 PM   #1
Stairguy
orange peel prevention?
I prime a lot of 1x poplar for prefabbed staircases. the boards are sanded to 80g and then the zinnser oil-based primer is applied with a 1/4" nap roller. After they dry they are sanded quickly with a DA orbital to get them a little smoother. Many times if the primer is applied too thick i will get an orange peel look which drives the finish painters crazy. For a quick fix I will just sand the primer a little bit extra until the surface is smooth. Is there any way to get a smoother finish without having to sand the heck out of them every time? Should i thin the paint..add penetrol?
Millertyme is offline   Reply With Quote
Old 01-17-2011, 06:29 PM   #2
You could put in some additives to make it flow out better. Are you sure that the Zinnser is the best for flow and leveling? My other suggestion would be to use a microfiber roller instead of a standard nap.
DIYHelper is offline   Reply With Quote
Old 01-17-2011, 06:53 PM   #3
Stairguy
what brands would you reccomend?
Old 01-17-2011, 09:29 PM   #4
ltd
you could thin a little or penetrol. if its a small amount i would brush only .for large amount roll to put primer on then brush it out
ltd is offline   Reply With Quote
Old 01-18-2011, 05:43 AM   #5
paper hanger and painter
chrisn's Avatar
http://www.thepaintstore.com/ArroWor...ver_p/mfr2.htm
DYIhelper has it correct.
chrisn is online now   Reply With Quote
Orange peel texture cracking dmdaniel Remodeling 5 10-23-2009 12:09 AM
orange peel when painting cabinets ponch37300 Painting 8 04-16-2009 11:55 AM
Best primer over orange peel texture? GFW Painting 2 12-04-2008 05:24 PM
Orange Peel Texture Help please kalaniwavo Painting 10 05-25-2008 06:39 AM
Same Ceiling: orange peel and knockdown sir_rob Painting 17 10-01-2007 05:28 PM
