Orange Peel? - Painting - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 08:33 AM   #1
Rewards Points: 2,040
orange peel?
Discovered when I ripped a pc of wallpaper off the kitchen that while it may come off easily it also takes off the top part of the bubbles forming the orange peel texture in the kitchen.
I sure don't want to sand all those walls.
Now what? Do you think when all the wallpaper is off and the walls are washed that it will improve anything? Is this normal for 30 yr old texture walls to lose the texture by crumbling?
What came to mind, was the look, in a very minute way, of barnacles.
Will a primer cover this up? What will I be facing in this project. Kitchen and 2 bathrooms.
Startingover is online now   Reply With Quote
Old 05-26-2012, 09:14 AM   #2
Gymschu's Avatar
Rewards Points: 240
Two options: 1. If you can live with a different looking orange peel texture (tops off of the texture) you could simply prime and paint. 2. If you can't live with the tops popped off the texture, you could skim coat the wall with joint compound to get them smooth again. This is a messy proposition but is doable. Do a search on here and you will find many threads about skim coating.
Gymschu is online now   Reply With Quote
Old 06-14-2012, 08:42 AM   #3
They must have had stripable vinyl wallpaper 30 years ago because it's peeled off very easily in large pieces.
Now what I discovered is that I'm left with very flaky stuff on the walls that crumbles off when I brush my hand over it. And in splotchy spots I see the actual gray drywall.
Besides washing with TSP and priming, is there any other prep work I should do?
Old 06-14-2012, 05:17 PM   #4
Mr. Paint's Avatar
That crunbly stuff is probably residual adhesive. You need to flood (Use a garden sprayer) the walls with hot water mixed with DIF wallpaper remover solution. After the paste softens, scrape the walls with a broad knife. Next, sponge-wash the walls with the solution and rinse with clear water; let dry completely.
Use Gardz primer on the wall first, fill irregularities with joint compound. When the walls are smooth, prime and paint.
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
Windows (06-14-2012)
Old 06-14-2012, 05:54 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 146
AFTER removing the paste
Old 06-14-2012, 10:45 PM   #6
Mr. Paint.
Whew. The more I do the more I think painters should be paid more.
I'm just glad there isn't a huge amount of wall space to do. Oops just realized when the kitchen is done I have 2 bathrooms to do the same thing in.
Is "Gardz" a name brand? Will I find it at Home Depot?
thanks,
Old 06-15-2012, 04:07 AM   #7
chrisn's Avatar
Rewards Points: 146
HD may have it, if not start here
http://www.rustoleum.com/zinsserhp.asp
Old 06-15-2012, 07:32 AM   #8
thanks,
Just read about Gardz and can't believe there's a product for my exact problem (crumbley). That's amazing and I'm so lucky to learn about it here.
Orange Peel Texture Help please kalaniwavo Painting 12 07-13-2015 03:48 PM
Applying mud over existing orange peel texture sunnywalls Drywall & Plaster 0 01-27-2012 09:03 AM
Orange Peel over Orange peel bigjon Painting 1 11-16-2011 03:24 PM
orange peel when painting cabinets ponch37300 Painting 8 04-16-2009 11:55 AM
Same Ceiling: orange peel and knockdown sir_rob Painting 17 10-01-2007 05:28 PM
