-   -   Options for metal gate paint or process (http://www.diychatroom.com/f4/options-metal-gate-paint-process-174491/)
jfryjfry 03-14-2013 09:01 AM
I just made a pair of steel gates, 13' long each, for the driveway and don't want to ever have to deal with rust or repaint again.
Without going into detail, there are a lot of pieces laying next to each other but not welded the whole way so ill have bare metal inside but want to seal it up so it won't rust and run down.
I'm going to make them black so it should help hide any rust running down.
Can anyone suggest kinds of paint to use that will last and will seal up the joints?
I thought about bondo-ing the joints but think that the vibrations and movement might crack it.
Or any processes that wouldn't cost an arm and a leg? Powder coating would be great but how much? A neighbor suggested galvanizing but I have no idea on the cost of that.
Thanks!
joecaption 03-14-2013 09:19 AM
Got a picture?
If it was welded right there would be no leaks.
Powder coating or taking it to an auto body shop and have them paint it are two options.
jfryjfry 03-14-2013 02:34 PM
I'm not sure how to post pics but the I welded parts are the joint where I welded a piece of 6" wide flat stock to the front of the 1.5" square tube frame. So from the front it looks like t is 6" wide.
I stitched it as welding both sides where the flat meets the square tubing would be over a hundred feet of welding total.
jfryjfry 03-14-2013 02:35 PM
Anyone familiar with asphalt paint? A rustic beaten look is great and I've heard this stuff is thick, rough and tough. Experience? How to prep the metal for it? Suggested brands?
housepaintingny 03-14-2013 03:51 PM
I like using Sherwin Williasm Kem Bond HS primer n bare metal-steel and painting with Sherwin Williams DTM or DTM enamel semi gloss sheen
mantis999 03-17-2013 03:14 PM
I use Hammerite metal paint
Canarywood1 03-17-2013 03:51 PM
You can check this out.
http://www.por15.com/prodinfo.asp?number=SSKB
ToolSeeker 03-17-2013 06:16 PM
Originally Posted by Canarywood1 (Post 1139523)
what I would recommend Paint Over Rust 15 We used it on wrought iron railings where I used to work. Not the easiest thing to work with thick and anything you get it on it is going to stay on including you. We used it also for the frames on Hot Rods.
