One Wall Two Textures Double The Headache - Painting - DIY Chatroom Home Improvement Forum
Old 09-20-2013, 09:14 AM   #1
Renovating My Land Yacht
Rewards Points: 616
One wall two textures double the headache
Been so focused on getting the TO point of painting that I forgot to ask the following
Bottom half of walls and ceiling are new drywall. Top half of some walls are original drywall with original paint in some type of super gloss....not just any gloss, but "in your face gas station restroom kinda gloss" . I have no idea what type of paint this is.
I did cover one upper with Valspar high hiding primer about a month ago (pepto bismal pink was driving me nuts) and just ran the tape test last night and its seems to have stuck. Does this confirm that its not oil based? Is there another way to test? Its either a really thick paint or they used like 12 coats.
Based on this, do I use the pva on the new drywall and the regular primer on the old drywall or, can I use the pva primer/sealer on both? Does using two primers make a difference to the finish coats?
I know that I will need to sand down the old wall and have already fixed any (lots) of nail pops and tool marks etc.
Robyn
forcedreno2012 is offline   Reply With Quote
Old 09-20-2013, 11:03 AM   #2
cdaniels's Avatar
One way to test for oil paint is with denatured alcohol on a rag.If the alcohol takes it off,it's not oil.I wouldn't use 2 different primers.Scuff sand the gloss paint and prime it all with a bonding primer like Zinser 1-2-3.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
ToolSeeker (09-20-2013)
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
double wall framing (interior walls) mpb Building & Construction 2 01-10-2013 07:17 PM
Fireplace and Double Wall B Vent Duddy HVAC 5 12-28-2012 01:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
