Olympic Rescue It! Or Rustoleum Restore?? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2013, 02:25 PM   #16
Too Short? Cut it Again!
This stuff I have seen applied is no darker than some stains people put on their decks. It does not seem to come in lighter colors though. I don't think the material itself generates heat or it is radioactive. I say again that outdoor rugs are now dirt cheap and will protect decks just like area rugs insided protect flooring. Little fififoofoo will not burn her paws on a rug.
My concern with these resin thick products is they may mislead consumers (although Rustoleum is a company least likely to do so). In looking at the YouTube instructions for Restore it shows filling in cracked and weathered decking with two or more coats. Whether this translates to the situation the OP has we do not know. We have not seen his/her deck.
At some point you have to honor the decking screaming DNR! at you. All the alternating breaths and chest compressions will not save it no matter the claims of miracle products. And I agree you could just worsen things sealing it with something that might micro-fracture and trap moisture. Again I admit having no experience with these products though. Maybe they will last for 100 years or whatever they claim.
By the way OP? If your goal is just to try and squeeze a few more years out of the decking? Have you tried flipping a board to see what the bottom side looks like? You might get lucky and find what you seek cheaper than with these restoration products.
The Following 2 Users Say Thank You to user1007 For This Useful Post:
Gymschu (07-31-2013), ToolSeeker (07-31-2013)
Old 07-31-2013, 02:28 PM   #17
Originally Posted by heythereterry View Post
Any thoughts or incite would be great!
And by the way OP, this phrase makes some of us under the constant watchful eye of moderators nervous. You will find even talk of inciting reasonable thoughts, or riots, is not welcome here!
Old 07-31-2013, 03:12 PM   #18
heythereterry's Avatar
Ha fun discussions and debates.
I have never had a deck and the one I just got with my new home is in poor shape. I would say 10 or more boards need to be replaced because they are rotted out and the others are just weathered.
It appears that they used a solid type stain before and most of it is wore off with large chunks left on most of the hand railing.
The deck is huge around 1500 sq ft so cost is a concern.
After all the posts I am considering using Sherwin Williams DeckScape solid product for cost and a good feeling that it is made by a good company.
Not a deck expert and not to concerned about showing the beauty of the wood just want it to look nice and be protected so it will last me for another 5-10 years...
heythereterry is offline   Reply With Quote
Old 07-31-2013, 03:36 PM   #19
Lad, if the deck boards are rotting, you are not going to get another 5-10 years out of the deck no matter what you put on them. The finish cannot hold up if that under it is dead or dying. And I will post it again but the US Forestry Department did an extensive study of deck stains a few years back. The average life of products on new decking was three years. Granted, there was crap like Behr that last only one weighing the average. NO DECKING FINISH ON NEW DECKING LUMBER IS GOING TO LAST 10 YEARS. Get over it.
At this point are you really seeking our advice or affirmation for a decision you have already made? I am not sure many of us can be helpful the way you want in the latter sense. Flip the boards over and see if that buys you some time. If not, like the news or not? Do not shoot the messengers. You need to replace the deck if it is rotting or being eaten. Or get rid of it if you do not need it.
Old 07-31-2013, 03:47 PM   #20
My plan is to replace the rotting boards and cover the deck with a good solid stain every three years or so and hope the wood stays intact for the next 5-10 years. At that point I should have the funds to replace it...
The Following 2 Users Say Thank You to heythereterry For This Useful Post:
Gymschu (07-31-2013), ltd (07-31-2013)
Old 07-31-2013, 03:54 PM   #21
Have you crawled under and looked at the bottom side of the deck? Timber does not usually rot in only one direction. You don't want someone falling through this deck do you?
Old 07-31-2013, 03:59 PM   #22
I would say 90% of the wood looks fine from the top and bottom it's just a few select boards that are starting to rot in some areas. The only thing I don't like with most of the others is there are some large knot holes in them say over 1" in size. I would estimate 20 of them over the whole deck. My main issue like I mentioned is budget so I am looking for a good way to protect the deck so I can save to replace all the wood in the future.
Old 07-31-2013, 06:40 PM   #23
ltd
Rewards Points: 536
roll that deck scapes solid on at a good spread rate .then back brush as you go don't be stingy with stain. fill cracks with stain and keep a wet edge .save your back and get a big brush that screws onto a stick .I seen a nice one at big orange . p/s that other stuff looks like a dirt, moss, mildew ,magnet.
ltd is offline   Reply With Quote
Old 07-31-2013, 09:50 PM   #24
Rewards Points: 4,792
The bottom of the wood is still "open", so you are not sealing off any chance of the wood "breathing". I think your plan is well worth trying. However I'm not sure what the maintenance plan would be for a product like Restore. The survey mentioned previously likely did not include products such as Restore. It just doesn't have enough years under its belt nor enough applications as compared to regular stain/sealer to make conclusions, I think.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
user1007 (08-01-2013)
Old 08-17-2013, 04:29 PM   #25
Just applied Rescue It
Last week I applied "Rescue It" to 720 sq ft of 10 year old treated wood 5/4 inch decking that had been stained two other times over the years with regular deck stain. The color used was "Cypress Earth" which is a medium tan with a tinge of light gold. As mentioned in other posts, it does go on thick. I did a lot of prep work using the advice that the video that Olympic has on their web site. I washed the decking letting it dry for a couple of days, sanded the really rough places, filled the larger/deeper cracks with an acrylic weatherproof paintable caulk letting it dry overnight. I then used a 1/2 in nap roller to apply the first coat which soaked in but covered sufficiently and again let dry overnight. I was very liberal with the stain in between board cracks and in surface cracks that didn't need the caulking, using a brush to apply and fill in the smaller cracks. The second coat went on with much less effort giving the surface a uniformed look making sure that the cracks between boards had the second coat also. Due to left over product of the 15 gallons that was purchased I applied a third coat and finished it by back brushing the deck surface. The finished surface does have an anti-slip texture to it from the acrylic chips that are within the stain. But this is what I was looking for to keep me from ending up on my butt when walking from the hot tub to the house during the midwestern winters. We had one 90 degree day since the work was done and I found that the surface wasn't any warmer to bare feet than regular deck stain. Total amount used, 12 gallons. Suggestion; buy less than what you think you need and purchase additional as needed to finish the project otherwise you will be wasting money on 32.00 gallon stain. For the railings and spindles, we used regular Olympic deck stain (two coats) of the same color and it matched up well. Bottom line; We'll see how it holds up to midwestern climate extremes over at least a 4-5 year period.
Diniman58 is offline   Reply With Quote
The Following User Says Thank You to Diniman58 For This Useful Post:
MikeKy55 (08-17-2013)
Old 08-17-2013, 05:03 PM   #26
These resin deck restoration products are fairly new so please post back. Again the US Forestry study on decking coatings and stains suggested an average of 3 years. I hope you get 5 out of this approach and maybe you will. Just mark your calendar and budget for 3 just in case?
Two other comments? You might want to update your profile so we know basic geographic information if needed or appropriate.
I am as longwinded as anybody on this site but hope I add paragraph breaks to all my posts. Your run on mass of type requires a real commitment to read.
Old 08-17-2013, 08:27 PM   #27
I'm doing a Restore application on a deck this week. I'll take pictures and post comments in another thread soon. Of course, no comments on longevity will be possible.
Gymschu (08-18-2013)
Old 08-17-2013, 10:51 PM   #28
Jmayspaint's Avatar
Rewards Points: 534
Originally Posted by Diniman58
Last week I applied "Rescue It" to 720 sq ft of 10 year old treated wood ..., . Due to left over product of the 15 gallons that was purchased ...Total amount used, 12 gallons.
Hi, thanks for posting your experience with this product.
I broke your post up a little, so I hope I haven't mis quoted.
Going by the numbers, it should have taken 14.4
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Old 09-30-2013, 11:56 PM   #29
After doing research on the main competitors, we went with DeckREFORM. We made sure not to apply during the heat of the day, and cut the mix with a little water before starting.
This gave it a slightly smoother (and more appealing for me) texture. You can check it out online, even buy from them or on Amazon hassle free.
pj420 is offline   Reply With Quote
Old 10-18-2013, 09:00 AM   #30
We I went with Sherwin Williams Deckscape. I must say I am glad I did because it looks great and the budget for the Rescue it or Restore would have killed me. I ended up using about 15 gallons and that was only one cote.
I will let you know how it holds up and post some pics soon.
Basement windows Toddr Windows and Doors 3 10-31-2012 07:14 PM
Help with my Egress Question brockmiera Building & Construction 19 10-30-2012 04:20 PM
how to go about making a window bigger in my basement so that I can put a bedroom urgurl031 Remodeling 12 10-07-2012 06:26 PM
Olympic Premium Flat and Semi-Gloss Ultra White fozzie Painting 15 12-07-2009 09:20 PM
Vista sp1 won't load. drive won't restore sv9779 PC Repairs & Upgrades 42 01-11-2009 11:36 AM
