Old Waterproof Paint Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 12:45 PM   #1
old waterproof paint peeling
Our basement floor has not been painted for many years and I do not remember what was used. We tried applying drylock waterproof paint and it began to peel as soon as it f dryed. Even the dryin itself took longer than it should have. Is there some sort of primer that can be used first?
lacksknowledge is offline   Reply With Quote
Old 09-26-2011, 03:34 PM   #2
Welcome lacks. It sounds like the hydrostatic pressure on the floor is greater than drylock can withstand. Normal drylock withstands 10 psi. Extreme drylock stops 12 psi. You might try that. But that's what you need to find--a stronger lock against the moisture. I don't know of any stronger, but you might find some on Google. If they fail, you need to go to another forum. Good Luck with it and keep us posted. Joe
Old 09-26-2011, 05:17 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Sounds to me like you are trying to put drylock on a previously painted floor, no can do.You will need to remove all paint in order for drylock to work, Sorry about that.
Old 09-26-2011, 08:57 PM   #4
Chrisn, I think he's putting it over the exposed concrete after it peeled. But it's a good point to bring to his attention.
Link looks good It's a nice website, basic, but nice and gets the point across. Has that been up long?
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Painting Old House Smokin Gun Painting 36 07-05-2011 02:24 AM
Peeling paint from old stucco johnny_ratchet Building & Construction 1 05-12-2011 01:18 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
