Old Walls - Painting / Drywall - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 12:24 PM   #16
Rewards Points: 6,034
That's about right i'm in Fla and it's $30 a gallon.
Old 01-01-2013, 09:22 AM   #17
Apprentice
Good morning...
The water/softener idea worked great.. It helped a lot... Yesterday I was able to finish 3 walls, now I only have pulp paper on 1...
Quick question: How long should I let Gardz dry for?
- Instructions say 24hrs, but I've searched a little and some people say they only wait around 15 minutes??
DSee is offline   Reply With Quote
Old 01-01-2013, 10:16 AM   #18
Rubbin walls since'79
Brushjockey's Avatar
The can says 1 hr- I don't know where you got the 24hrs.
It does dry very quick. One of the nice things about it.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-03-2013, 04:58 PM   #19
Apprentice
Gr...
Skim coat + gardz + sanding helped a lot... But.. There are a lot of holes in the wall... I can't seem to fix the imperfections... When I fix one place, I end up messing up another...
Old Walls - Painting / Drywall-img-20130103-00418.jpg   Old Walls - Painting / Drywall-img-20130103-00419.jpg
Old 01-03-2013, 05:10 PM   #20
Photo 1 needs that goober knocked off. Then if it makes a hole or divot that needs filled sanded and primed. Photo 2 looks like it just needs sanded then reprimed I know PITA but its really the best way.
Old 01-03-2013, 05:17 PM   #21
Basic problem I think is
1- how to apply mud
2- how to sand mud
Then priming is a cinch!
The Following User Says Thank You to Brushjockey For This Useful Post:
chrisn (01-04-2013)
Old 01-03-2013, 05:34 PM   #22
Mr. Paint's Avatar
That residual paste looks like it was covered by a fabric-backed vinyl. I would use DIF wallpaper remover solution mixed with hot water, spray it on the walls liberally with a garden sprayer and a shaver knife to scrape the paste off before doing anything. After you've washed and rinsed the walls, prime with Zinsser Gardz before doing repairs; re-prime with Gardz begore finishing.
The Painter's Paint Store where QUALITY is ECONOMY
Mr. Paint is offline   Reply With Quote
Old 01-18-2013, 11:45 AM   #23
Apprentice
Just stopping by to thank everything that contributed in this thread.
The final result wasn't perfect (again, I'm not a pro), but thanks to you I was able to fix 99% of the walls, it looks a lot better.
I appreciate the help!
The Following 3 Users Say Thank You to DSee For This Useful Post:
cdaniels (01-18-2013), Mr. Paint (01-18-2013), ToolSeeker (01-19-2013)
What's the best way to remove Plaster/Lath walls and replace with Drywall psubaron Building & Construction 31 02-14-2011 11:20 AM
Painting over damaged drywall... tmsurf8 Painting 4 08-19-2010 04:07 PM
Need help with painting my walls red over drywall repairs tdm71 Painting 4 08-02-2010 10:34 AM
Painting Walls Red Wazoe Painting 8 12-07-2009 11:07 PM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 04:21 PM
