Old 11-09-2009, 05:01 PM   #1
Old paint on unprimed walls?
Help! We have just moved into an old house (1950's), and decided to paint the lounge room. It turns out the previous owners have painted straight onto the plaster without priming it first, so the paint is bubbling off the walls. I've removed all the bits that are bubbling/flaking, but whenever I reach an edge of a sanded/bubbled area, the paint keeps lifting off around the edges, so I have to keep going.
Is there any way of sealing old paint onto plaster so we can just paint over it? Or even just sealing the edges of the areas that have lifted up?
Thanks in advance!
Marmalade is offline   Reply With Quote
Old 11-09-2009, 06:01 PM   #2
Matthewt1970's Avatar
You really need to scrape those spots back further till you get to where the paint is stuck well. Then prime the bare plaster.
Old 11-11-2009, 10:57 PM   #3
Thanks - will keep going with the scraping - makes you realise how big a room is!
Old 11-12-2009, 05:10 AM   #4
paper hanger and painter
chrisn's Avatar
After scraping off all the loose paint ,skimming,sanding,cleaning,I would apply a coat of Gardz primer,It will tend to "lock down" everything and get you ready for your finish coats.
Commenting on Behr Paints athanman Painting 657 02-12-2012 05:21 PM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
what colour should i paint my walls roxy Painting 4 03-08-2009 03:15 AM
While prepping my walls with TSP - paint bubbled! nikolita Painting 5 12-29-2008 01:29 PM
