Old Paint On A Porch, Pressure Water Will Not Take Off - Painting - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 03:06 PM   #1
Old paint on a porch, pressure water will not take off
I dont want to use solvents, what can I do
Jake22 is offline   Reply With Quote
Old 06-22-2010, 03:30 PM   #2
NAV
What are you trying to do, remove old paint splatter/spill?
scrape loose and peeling paint, and repaint the porch. There is no miracle paint removal fixer products.
NAV is offline   Reply With Quote
Old 06-22-2010, 07:31 PM   #3
jschaben
Rewards Points: 502
Hi Jake - Little more information would be useful. Belt sander, Disc Sander, Angle grinder, Scraper, Propane torch... Lot depends on what you are doing and what are you doing it oto.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-22-2010, 08:00 PM   #4
Learning by Doing
Leah Frances's Avatar
I LOVE my IR paint stripper. Quiet, low fire risk, doesn't volatilize lead, and pretty quick. Got a silent paint remover and then DH built one using a IR heating element meant for the culinary industry.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-22-2010, 08:26 PM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Can't expect the power washer to strip the paint for you, if it is really stripping the paint then you are damaging the wood too, as mentioned already there are differant methods to removing paint, but you probally just have to use a paint scraper and an orbit sander with 40/60 grit paper. Not really sure what your situation is?
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Leah Frances (06-22-2010)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 09:23 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
