-   -   old house (http://www.diychatroom.com/f4/old-house-22473/)
gbsk 06-18-2008 05:01 PM
old house
I am painting some rooms in my mom's house. There are crack that need repair. The worst are in ceiling. One runs down the center of the ceiling. I took off the loose plaster. It is not joint compound but very hard plaster. The seam between the gypsum or whatever they used in the ceiling is almost like concrete filled with about 1/2 inch gap with something like concrete.The plaster is so hard that I think it will mess up more if I take more off. Almost all of it is not wide enough to use tape and joint compound. I was thinking of using Quik -rete instead and keep wet troweling until it dries. Do people think this would work?
Allison1888 06-30-2008 01:42 PM
old house plaster repair
It might give you better adhesion. Another option is to patch in drywall if the spaces are big enough -- not sure how level it is and whether drywall would blend in or not? Perhaps post a picture?
mark942 06-30-2008 03:11 PM
Plastering is a system.Base,scratch,finish. With that being said the first thing you would have to do is reattach the edges of the crack back to the lath. If you do not do this the crack will just come back.It is loose plaster. I have used this system
http://www.plastermagic.com/faq.php
I saw it on a DIY program and gave it a try.It worked like a dream. Good Luck. :thumbsup:
