Old Damaged Wall - Can This Be Fixed? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-24-2012, 08:07 AM   #16
Rewards Points: 83
The wall feels like 150-grit sand paper now after applying it.
So after I put the all purpose compound over the Gardz, i will use the Gardz again and cover the whole wall area with it?
And then I will use the paint for the bathroom.
I was planning on using:
Benjamin Moore - Aura Bath & Spa - Matte Finish
thx
blwegrzyn is offline   Reply With Quote
Old 04-10-2012, 10:11 AM   #17
Rewards Points: 83
so i put the initial all purpose compound, and now i want to make sure that i do it right,
i will do second layer of the compound to fill in any imperfections left after first plastering,
then i will do the sanding and then i will cover whole area with Gardz (initially i only used Gardz on broken area)
no primer will be used,
then i will paint the wall according to this guide:
http://www.benjaminmoore.com/en-us/for-your-home/fresco
are my steps in the correct order?
thx
Old 03-06-2016, 05:05 PM   #18
Rewards Points: 83
mistake post
mistake post
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
How do I replace damaged siding in the middle of the wall? sofasurfer Building & Construction 4 07-07-2011 07:28 AM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
