Old 06-21-2006, 02:19 PM   #1
They're all fixer-uppers
J187's Avatar
Ok to wait 74 hours between coats?
Are there ANY problems at all associated with waiting a couple of days after one coat is applied to get to the second coat? I've got a schedule problem
J187 is offline   Reply With Quote
Old 06-21-2006, 05:02 PM   #2
The instructions on the paint should indicate the time period to re-coat.
Is the first coat a primer coat?
Is the secodn coat a finish coat?
I would think that it should not be a problem.
redline is offline   Reply With Quote
Old 06-21-2006, 05:13 PM   #3
J187's Avatar
The wall has been primed and coated once w/ the paint. This would be the second and hopefully finishing coat of paint. The instructions only give me the minimum amount of time to wait, doesn't really say anything about how long is TOO long. Thanks.
Old 06-21-2006, 05:20 PM   #4
If you apply the second coat well after the minimum as stated on the can then you should be safe.
Old 06-22-2006, 04:33 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Nope, you're fine
If you do some woodcutting and get sawdust on them or we get another pollen dump that coats the walls, just clean them up first
That's all, just no dirt or dust
slickshift is offline   Reply With Quote
Old 06-23-2006, 05:37 PM   #6
Pro Painter
AAPaint's Avatar
I'd like to mention though that you don't want to wait longer than say 5 days between coats. Latexes usually cure in about seven days, and you want the coats to cure together to provide one protective film. Most manufacturers say be sure to recoat before 7 days. Same would go for oil, but they have a much longer cure time usually around 30 days.
This is for finish coats. Although you wouldn't want to leave a primer sitting much longer either. You won't hurt anything waiting just a few days.
AAPaint is offline   Reply With Quote
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
Be honest, do you really do three coats on everything? KUIPORNG Remodeling 18 03-30-2007 04:02 PM
24 hours curing time enought? KUIPORNG Flooring 4 02-28-2007 09:23 AM
Why no water hours after friend pulled our pump? sheriffherself Plumbing 4 11-19-2006 08:10 AM
Do I need to prime first or will 2 coats be enough? candy Painting 3 07-17-2005 03:04 AM
