-   -   Ok to wait 74 hours between coats? (http://www.diychatroom.com/f4/ok-wait-74-hours-between-coats-2819/)
J187 06-21-2006 01:19 PM
Are there ANY problems at all associated with waiting a couple of days after one coat is applied to get to the second coat? I've got a schedule problem:mad:
redline 06-21-2006 04:02 PM
The instructions on the paint should indicate the time period to re-coat.
Is the first coat a primer coat?
Is the secodn coat a finish coat?
I would think that it should not be a problem.
J187 06-21-2006 04:13 PM
The wall has been primed and coated once w/ the paint. This would be the second and hopefully finishing coat of paint. The instructions only give me the minimum amount of time to wait, doesn't really say anything about how long is TOO long. Thanks.
redline 06-21-2006 04:20 PM
If you apply the second coat well after the minimum as stated on the can then you should be safe.
slickshift 06-22-2006 03:33 PM
Nope, you're fine
If you do some woodcutting and get sawdust on them or we get another pollen dump that coats the walls, just clean them up first
That's all, just no dirt or dust
AAPaint 06-23-2006 04:37 PM
I'd like to mention though that you don't want to wait longer than say 5 days between coats. Latexes usually cure in about seven days, and you want the coats to cure together to provide one protective film. Most manufacturers say be sure to recoat before 7 days. Same would go for oil, but they have a much longer cure time usually around 30 days.
This is for finish coats. Although you wouldn't want to leave a primer sitting much longer either. You won't hurt anything waiting just a few days.
