Is It Ok To Use A Flat Paint Instead Of Primer - Painting - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 08:07 AM   #1
Is it ok to use a Flat Paint instead of Primer
We're finishing our basement and my wife and I both work from our home several days a week. We also have a bird and I have respiratory allergies.
Therefore we'd like to use the healthier paints with low-odor and zero VOCs.
We have decided to go with Sherwin Williams as they have a great sale on paints this weekend (40%). Unfortunately, their primer is not on sale and it's $40 per gallon for the cheapest "healthy" primer.
The store manager recommended that we prime with the Flat Paint of the cheaper "healthy" paint line which is HGTV and costs $22 and then add a top coat of the Harmony which is their premium "healthy" paint which is $33 on sale. Strangely, both are cheaper than the primer:-)
Can I use the real paint as the primer?
Thank you,
Paintbird
PaintBird is offline   Reply With Quote
Old 04-20-2012, 08:13 AM   #2
Too Short? Cut it Again!
Primer and paint are not the same thing. Chemistry and purpose are different. You should use a primer and the store person should not have suggested using flat paint as a primer. Something like Zinser 123 is good stuff and may be cheaper than the SW primers.
And don't get too worked up about the VOCs in the waterbased primer you pick. I can rattle off a list of things in your home that effect air quality and your allergies, and outgas potential toxins much more than paint and primer.
The Following User Says Thank You to user1007 For This Useful Post:
PaintBird (04-20-2012)
Old 04-20-2012, 09:19 AM   #3
I just found out that the primer is also on sale so I'll be using the healthy primer. Since the drywall has never been sealed or primed, I agree that a primer would be a better application than flat paint.
Thank you for your replies!!!
Old 04-20-2012, 09:27 AM   #4
Bravo! Should last you awhile.
Old 04-20-2012, 04:43 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
I am with sdsester, whenever possible use a primer on bare drywall, especially in a basement.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Commenting on Behr Paints athanman Painting 657 02-12-2012 04:21 PM
Flat paint help in apartment cnj419 Painting 4 02-24-2011 07:07 PM
Painting over flat paint in bathroom lewisj Painting 2 03-17-2009 04:12 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 08:13 PM
