OK To Put Latex Satin Over Latex Semi Gloss? - Painting - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 04:03 PM   #1
Rewards Points: 1,062
OK to put latex satin over latex semi gloss?
Just wondering- the semi was done years ago. Guess I can lightly sand walls to help, eh? Hope I dont have to prime.....
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 02-05-2013, 04:57 PM   #2
Gymschu's Avatar
Rewards Points: 514
Noquacks, it depends. I usually scuff sand somewhat aggressively to give that Satin something to bite onto. Wipe off the dust and maybe test a small area to make sure of adhesion. If you see a separation of paint then you will have to prime with a bonding primer.
The Following User Says Thank You to Gymschu For This Useful Post:
noquacks (02-05-2013)
Old 02-05-2013, 05:49 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
95% of the time, this will work just fine, you might have to do a little more than lightly sand though.
Old 02-06-2013, 06:02 PM   #4
Grants Painting's Avatar
Satin over Semi-Gloss
As long as you are using a good quality paint you should be fine with a light sanding. In fact every wall that you paint a satin or above on should be lightly sanded anyway.
Grants Painting is offline   Reply With Quote
How to protect semi gloss latex paint on wall clorenc Painting 1 04-28-2012 03:09 AM
Semi Gloss Or Satin In Old House NewEnglandYank Painting 14 01-21-2011 02:37 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 04:47 PM
