OK to put latex satin over latex semi gloss?
Just wondering- the semi was done years ago. Guess I can lightly sand walls to help, eh? Hope I dont have to prime.....
Thanks |
Noquacks, it depends. I usually scuff sand somewhat aggressively to give that Satin something to bite onto. Wipe off the dust and maybe test a small area to make sure of adhesion. If you see a separation of paint then you will have to prime with a bonding primer.
95% of the time, this will work just fine, you might have to do a little more than lightly sand though. |
Satin over Semi-Gloss
As long as you are using a good quality paint you should be fine with a light sanding. In fact every wall that you paint a satin or above on should be lightly sanded anyway.
| All times are GMT -4. The time now is 03:35 AM. |
