Is It OK To Paint Near A Furnace In Winter? - Painting - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 06:49 AM   #1
Caution! Girl working
Is it OK to paint near a furnace in winter?
Hello
Is it OK to prime furnace room walls in winter?
I'd be using Sherwin Williams exterior concrete primer to prime below-grade concrete walls in a room that's about 15 x 20 and has an oil-fired furnace, which will be running. I can put a fan in the doorway to help ventilate, but the window doesn't open (it's being replaced in the spring).
Mostly I'm worried about the fumes being flamable? I know you're not supposed to paint near 'open flames' but does a furnace count as an 'open flame'?
Thanks much!
ADaniLion is offline   Reply With Quote
Old 12-18-2012, 07:01 AM   #2
Gymschu's Avatar
Rewards Points: 838
Yes, a furnace counts as an open flame as do water heaters. Wait til spring since you will be replacing a window anyway and messing up the walls. Just do it all SAFELY in the Spring.
Old 12-18-2012, 07:18 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
I don't know that paint, but any waterbase paint does not have flammable fumes, and would be fine.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (12-18-2012)
Old 12-18-2012, 07:50 AM   #4
The water heater's electric so that shouldn't pose a problem. The paint is latex. Bummer if I have to wait till spring but I will of course if it's dangerous.
Old 12-18-2012, 09:20 AM   #5
Rewards Points: 394
Latex paint is not affected by flame, as the fumes will not ignite. Brushjockey is correct.
Will22 is offline   Reply With Quote
Old 12-18-2012, 10:37 AM   #6
Gymschu's Avatar
Rewards Points: 838
Oops, sorry about the bad advice. Didn't catch the WATER-based portion of your post. Paint away!
Old 12-20-2012, 11:16 PM   #7
he is rite you should use latex paint . the are good for the areas like furnaces e.t.c.
paulsmith544 is offline   Reply With Quote
Brand New Concord Furnace Doesn't Work In Cold Weather LeighC HVAC 21 01-07-2013 08:48 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
