-   -   Is it OK to paint near a furnace in winter? (http://www.diychatroom.com/f4/ok-paint-near-furnace-winter-166760/)
ADaniLion 12-18-2012 06:49 AM
Hello :)
Is it OK to prime furnace room walls in winter?
I'd be using Sherwin Williams exterior concrete primer to prime below-grade concrete walls in a room that's about 15 x 20 and has an oil-fired furnace, which will be running. I can put a fan in the doorway to help ventilate, but the window doesn't open (it's being replaced in the spring).
Mostly I'm worried about the fumes being flamable? I know you're not supposed to paint near 'open flames' but does a furnace count as an 'open flame'?
Thanks much!
Gymschu 12-18-2012 07:01 AM
Yes, a furnace counts as an open flame as do water heaters. Wait til spring since you will be replacing a window anyway and messing up the walls. Just do it all SAFELY in the Spring.
Brushjockey 12-18-2012 07:18 AM
I don't know that paint, but any waterbase paint does not have flammable fumes, and would be fine.
ADaniLion 12-18-2012 07:50 AM
The water heater's electric so that shouldn't pose a problem. The paint is latex. Bummer if I have to wait till spring but I will of course if it's dangerous.
Will22 12-18-2012 09:20 AM
Latex paint is not affected by flame, as the fumes will not ignite. Brushjockey is correct.
Gymschu 12-18-2012 10:37 AM
Oops, sorry about the bad advice. Didn't catch the WATER-based portion of your post. Paint away!
paulsmith544 12-20-2012 11:16 PM
he is rite you should use latex paint . the are good for the areas like furnaces e.t.c.
