OK To Add Water To Semi-gloss Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 05:14 PM   #1
OK to add water to semi-gloss paint?
I have some Benjamin Moore Regal that the lid hasn't fit well on that's been around a while but it's half full. It seems like it is a little thicker than when new.
I painted a few doorframes and it looks fine, but it seems to dry fast.
Is it ok to thin with a little water?
mjzraz is offline   Reply With Quote
Old 04-07-2013, 05:21 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
yes, a little
Old 04-07-2013, 07:37 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 846
A little water is ok and pour the paint thru a strainer too since it's been sitting for a while.
Sir MixAlot is offline   Reply With Quote
Old 04-07-2013, 08:16 PM   #4
Originally Posted by chrisn View Post
yes, a little
Thanks!
Thanks! Good idea on the strainer the lid was rusty around the edges so Im sure there is some junk in there.
Trim and crown moulding was ok, but when i was doing a large door I was having to move fast to keep the paint from getting tacky and dragging. I hate to waste paint, especially the good stuff. I think this bedroom project will use it up otherwise I would put the leftovers in a better container.
The Following User Says Thank You to mjzraz For This Useful Post:
Sir MixAlot (04-07-2013)
Old 04-07-2013, 11:19 PM   #5
Rewards Points: 4,780
It's the solvent in the paint, not the sheen, that determines if you can add water to it :-)
jeffnc is offline   Reply With Quote
Old 04-08-2013, 12:58 AM   #6
Not sure what I was thinking there - should have said OK to add water to acrylic paint?
Old 04-08-2013, 01:01 AM   #7
It's always OK to add water to water based paint - in the sense that you're not going to screw up the chemistry. Might not accomplish what you want, but in your case probably will.
Old 04-08-2013, 10:29 PM   #8
Painting Contractor CT
Rewards Points: 77
Post
Yes definitely can. You can add water to latex paint but not too much, just enough so that it is easier to apply. Good Luck!
KD PAINTING is offline   Reply With Quote
Old 04-09-2013, 12:08 AM   #9
Too Short? Cut it Again!
An additive and conditioner is what I would do rather than thinning the paint with water. Floetrol is one brand.
Can should have a recommendation for how much water you can add. Better to add a little and try it. You cannot take it back out!
Make sure you are using a good brush and don't overwork your surface.
Old 04-09-2013, 01:03 AM   #10
But in this case you probably aren't really thinning the paint, because water is probably exactly what the paint has lost and therefore what it needs to get back to original composition. Floetrol won't hurt, but the solids in Floetrol aren't what has evaporated from the paint (assuming that's what happened.)
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
painting brick on top of existing paint / water proofing basement 2md Painting 8 12-14-2010 11:11 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
