Oil Vs. Water Based Primer - Painting - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 07:39 PM   #1
Oil vs. Water Based Primer
Folks, What is the difference between oil and water primer and how do you choose when to use which?
dzobrist is offline   Reply With Quote
Old 01-16-2012, 09:30 PM   #2
A Little Of Everything
Rewards Points: 1,364
In overly simplified terms, one is an oil carrier while the other is a water carrier.
Your choice of what kind of primer to use (there are more choices than just oil or latex) really depends entirely on what you need it to do.
So... What do you need it to do?
DrHicks is offline   Reply With Quote
Old 01-16-2012, 09:31 PM   #3
Too Short? Cut it Again!
What you need to know and think about is has to do with the film you plan to leave behind.
Think about water and oil solvents as only the suspension for the film for a second. And think about everything you remember from junior high chemistry class. Oil and water do not mix well. Except in lava lamps made here in Chicago.
You can try to put an "oil" finish over latex but I promise it will not work. You can put latex or acrylic over oil and it might work. What you need is an equalizing film.
Alkyd. Or as mentioned and if you can afford them, some of the new primer film surfaces.
Alkyd used to be suspended only in stinky oil solvents. You can know get it in latex (soap and water cleanup products).
Old 01-16-2012, 09:34 PM   #4
jschaben
Rewards Points: 502
The good dr has a very good question. What are you doing?
I have been using oil based primer on plywood projects where I don't want the wood grain telegraphing through to the top coat. Water based primers seem to raise the grain enough it takes two or three coats of primer with sanding in between to achieve what I want where I can get the same effect with one coat of primer and a light sanding.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
Gymschu (01-16-2012)
Old 01-16-2012, 09:38 PM   #5
That would be absolutely nothing except that a cute girl sat across the table from me...
Old 01-16-2012, 09:45 PM   #6
Great point but what are you doing? Seal the wood before priming if your concern is "telegraphing" wood grain to the surface. In all my years I have never found a need to apply more than one coat of primer.
Old 01-16-2012, 10:14 PM   #7
jschaben
Rewards Points: 502
Could be that great plywood I've been getting from Home Depot, my local "real" lumber yard is even worse, construction grade stuff only. A heavier primer like Gripper may work better, haven't tried that yet but Cover Stain has been working well for me lately. I guess that's technically an Alkyd but it is oil borne.
I suppose I could use a sanding sealer, never really thought about that because primer is cheaper.
John Schaben
Old 01-17-2012, 01:17 PM   #8
Oil V Water Primer use
I have two things I want to paint
1) Drywall
2) unfinished cabinets
Old 01-17-2012, 09:21 PM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
1) Drywall
Prime your drywall with Latex. The unfinished cabinets will do better with an oil based primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
DrHicks (01-17-2012)
Old 01-17-2012, 09:51 PM   #10
Rubbin walls since'79
Brushjockey's Avatar
Best primer for raw wood in oil in my experience is BM's Enamel Underbody. Sands up like a dream.
Best Waterborne for me on raw is Zin's Primecoat2. Also sands up nice.
Only at HD I think.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Tags
oil , primer , type , water
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Zinsser 123 Water Based Primer - Dry Time sharingsunshine Painting 4 10-18-2011 11:33 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
