Oil Spots(?) Bleeding Thru Paste Filler On Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 01:43 PM   #1
Rewards Points: 77
Exclamation
oil spots(?) bleeding thru paste filler on cabinets
I'm prepping some built-in cabinets for painting.
IAW this forum's (and other) advice, I washed the cabinets 2Xs. 1 time with soap and water, and 1 time with a paint prep "orange cleaner." I also sanded them.
Next I applied a paste filler to hide the grain. BUT it has dried and now I see several oil/grease spots bleeding thru it. YIKES! They appear most frequently around the place where the old cooktop was, and around the sink.
Now what do I do?
a) Sand down (what grit?), and reapply the paste filler?
b) Sand lightly, and apply another coat of paste filler?
c) Nothing, but make sure I apply a good stain blocking primer?
TIA!!!
Last edited by 1655graff; 01-17-2008 at 01:45 PM. Reason: oops, forgot a sentence.
1655graff is offline   Reply With Quote
Old 01-17-2008, 08:03 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
I don;t know what a paste filler is, but I can pretty much tell by the name it's not a sealer
You need to seal those stains
Depending on what finish is on there now, and what finish you want to put on their, I'd suggest a pigmented shellac off-hand
Though an oil-based sealer may work also, the shellac is the strongest for no worries
slickshift is offline   Reply With Quote
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 07:48 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
